ahhh bad news fir my new engine!!!
Old 07-16-2011, 07:37 PM
saylorZ28's Avatar
Default ahhh bad news fir my new engine!!!
well actually got to run my car today and drove it good ... and geuss what a mustang pulls up at the light ... so i said hell lets run em ... after the run my steering got hard and i pulled over at the motor had spun the crank hub off the crank .... 300 miles and its shot got to pull it and redo it .. if i dont decide to part it out .... is it possible too just change the crank and not have to complety tear it down
Old 07-16-2011, 07:44 PM
shbox's Avatar
Not really possible.
Old 07-16-2011, 07:58 PM
Big Al's Avatar
If you pull the engine and turn it upside down you can change the crank. Have to remove the oil pan, timing cover, and take your time. Would save you the intake set and head gaskets, but it will cost you in time as you have to protect the new crank from all the rod bolts. And work the rod/piston up and down without damaging something.
Before you do something rash, have a look at what happened to the crank nose. You may be able to repair it in the car. Pull the balancer and hub and look the crank over. See if the bolt broke or if it's intact. You may be able to buy a new hub and make it work. When you get it off send some pictures and if you have a way, measure it.
Al
Old 07-16-2011, 08:12 PM
saylorZ28's Avatar
ahh no the bolt is fine the hub is hollowed out bad and the crank is ground down it will just sit there and spin i can spin it by hand easily and shew i'm just mad as hell
Old 07-16-2011, 09:46 PM
henry172's Avatar
Did you at least beat the mustang? I know how you feel I just finished my le1 355 build and I am thinking I have a spun bearing with less than 100mi on the engine; my oil looks like it has glitter in it.
Old 07-16-2011, 10:06 PM
RamAir95TA's Avatar
Why didn't you install a keyed hub? Pretty common practice with a performance build.
Old 07-17-2011, 09:13 AM
saylorZ28's Avatar
just used the factory hub and the crank had the key in it ... i duno? oh i tore his *** in the mustang but he did drive off i got a tow lmao
Old 07-17-2011, 09:23 AM
Village Troll
SS RRR's Avatar
..... is it possible too just change the crank and not have to complety tear it down
Sure. Anything is possible. Just don't count on the engine lasting all that long. How did it just spin off the crank? Was the crank hub bolt present when this happened? How is it the crank is shot?
Old 07-17-2011, 12:06 PM
Big Al's Avatar
Get a new hub and see how loose it is. Let us know. You can fix it if it is not too bad. Don't panic.
Al 95 Z28
Old 07-20-2011, 06:30 PM
saylorZ28's Avatar
sry guys left for vacation got my mind off things gona take some pics tomorrow ....
Old 07-21-2011, 06:38 AM
93v8clone's Avatar
if ya throw a new crank in it and dont balance it your gonna have problems . at all aspects of it . i know it sucks but pull it and build it again , like said before for the cheap insurance have the crank and hub machined for a key lol
