Boost a stock LT1??
Old 07-17-2011, 05:13 PM
ALH442's Avatar
Question Boost a stock LT1??
Just woundering if you can run a twin set up on a mostly stock lt1.I am in the process of rebuilding my motor nothing fancy just freshing up and cam.I can pick up 2 T3/T4 turbo's cheap.just woundering if it will handle 5~7 lb of boost on a stock bottom end?
Old 07-17-2011, 09:36 PM
96capricemgr's Avatar
A lot of rebuilds are a step BACKWARDS from stock.
While I would trust a stock shortblock at that level I wouldn't feel comfortable commenting on your "rebuild" without knowing exactly what you are doing.
Old 07-17-2011, 09:55 PM
pro94lt's Avatar
Man he really is right... Just do it right, don't skip the little speps in a build, pull timing, add some fuel to and you'll be ok also don't hot lap it.
Old 07-17-2011, 10:39 PM
whytryz28's Avatar
Just throw a bottle on it.
Old 07-18-2011, 06:08 AM
ALH442's Avatar
New bearing's seal's,gasket's,valve job, the motor has 120xxx and was not serviced on a regular schedual.So basicly just a freshing up more than rebuild
Old 07-18-2011, 06:41 AM
moehorsepower's Avatar
Just remember any type of power adder be it nitrous or forced induction will amplify what ever weak part is there and find it.....
Old 07-18-2011, 06:51 AM
Village Troll
SS RRR's Avatar
I would do a leakdown first to see what kind of shape the cylinders are in before boosting. As long as you remain conservative on the boost (levels you mention) as well as a spot on tune you will be fine. Most boosted applications on the stock shortblock grenade because people either get greedy, their tune is off or all the above resulting in ejecting ringlands out the exhaust, and of course the hyper-u pistons are then blamed instead of their own incompetence.
Old 07-18-2011, 08:31 PM
ALH442's Avatar
Im only looking for 325~350 rwh i dynoed 271 hp 286 tq through a 4l60 and stock stall.I have a t56 to swap in.This will be handed down to my son so do not need a 16 year old with 450rwh all of everyones input is beeing verry helpful
Old 07-18-2011, 08:35 PM
RamAir95TA's Avatar
If that's all you need, a mild cam install is all you need. It will be FAR cheaper and FAR more reliable than a supercharger build.
Old 07-18-2011, 09:19 PM
hitmanws6's Avatar
Yeah just do a cam, the swap will be about as much as the accessories needed for FI
Old 07-19-2011, 12:43 AM
"I MAID THEESE"
Mavn's Avatar
Agree on cam. Noboby hate.. But... Get the lt4 hot cam kit and all bolt-ons and you will be happy.
Old 07-19-2011, 07:58 AM
Yup, you will be bashed, I don't know what the kit cost now but back in 97 I purchased the entire kit, cam, springs, Rockers (Which used to be crane) and with bolt ons, stall my car ran 12.6's all day long.I dont know what RWHP that equated to but thats plenty fast for a 16 year old, He surely will fly by those Winged Fart machines...
Old 07-19-2011, 08:00 AM
quik95lt1's Avatar
stock motor in good shape will handle 7-9psi......
Old 07-19-2011, 08:11 AM
Z28Roxy's Avatar
At least get some heads and head gaskets that will drop the compression ratio.
Old 07-19-2011, 09:50 AM
Why go to all that trouble and cost when you can limit the RPM & Speed via computer tuning. I did that once for a dad that built a car for his son. the potential was there but I limited the rpms and top speed to what he wanted, He said as he grew older and got more experience then he would have me raise the rpms and mph...unless you are talking about lowering the compression for boost which is a total waste on a stock motor..
Old 07-19-2011, 10:03 AM
ahritchie's Avatar
Seems pointless and costly to supercharge it for only 50-75 HP gain...as mentioned you can get that with a cam and full bolt-ons. However, I did notice one of those low-boost baby powerdyne superchagers from back in the day that only makes 4.5-6 lbs of boost in the classifieds...the stock LT1 should take that with no issues as long as it's tuned good; would also make about 50-75 more RWHP. It is non-intercooled however and not the best supercharger (may need rebuild regularly) but they are as cheap and simple as it gets for boosting a LT1.
Old 07-19-2011, 10:05 AM
RamAir95TA's Avatar
I 'd when I read "may need rebuild regularly." Typical maintenance, right?
Old 07-19-2011, 10:14 AM
I think what he meant is the old powedynes were belt driven, I mean internally, not geared like other superchargers and those belts would not last long..
Old 07-19-2011, 10:17 AM
ahritchie's Avatar
You should pick up this bad-boy for your car: https://ls1tech.com/forums/parts-cla...arger-lt1.html
Old 07-19-2011, 12:02 PM
Z28Roxy's Avatar
He is already doing a valve job...
Quick Reply: Boost a stock LT1??
