Superflow 600 Numbers
Old 07-20-2011, 07:36 PM
LT1capriceclassic's Avatar
Default Superflow 600 Numbers
These heads came out of a 95 Buick Roadmaster.
STOCK:
valve lift cfm
.100------------58.2
.200------------105.4
.300------------151.6
.400------------178.8
.500------------187.5
After some mild port work:
valve lift cfm
.100-----------58.4
.200-----------100.2
.300-----------154.2
.400-----------187.4
.500-----------205.2
Numbers are from a Superflow 600. All flow data is at 28 inches of H20. All numbers are intake i have not had a chance to test the exhaust side yet. These numbers just seem a little low to me. Does anyone have any flow numbers for stock cast iron heads?
Old 07-20-2011, 07:43 PM
Puck's Avatar
STOCK:
valve lift cfm
valve lift cfm
.100-----------58.4
Why didn't you test to at least .600? The numbers were still climbing, and no cam worth installing is under .500 lift.
The numbers by themselves seem low, but flow benches are so easily skewed its not even funny...what was the bore size and fixture type?
Old 07-20-2011, 08:11 PM
i think it was a 4 1/4 inch boar on a plexy glass type fixture. i went to .600 and only got 1 more cfm so i didnt think it was worth posting.
Old 07-20-2011, 09:06 PM
nitrous2fast's Avatar
What is the cross-section area of the intake ports?
Quick Reply: Superflow 600 Numbers
