LT1 "cam only" dyno results/track numbers?
Old 07-24-2011, 06:51 PM
bufmatmuslepants's Avatar
Default LT1 "cam only" dyno results/track numbers?
For those who are cam only with stock heads/shortblock and full boltons, can you please post up your track times and/or dyno numbers? Also where you shift at going down the track.
I am currently at 12.53 at 110.33 full boltons MINUS rrs, gears, and ewp with mods in sig and need help choosing a cam for this winter, looking for used cheap parts for a cam kit anything from a hotcam to lloyds emissions friendly 224/230 to a comp 230/236. Anyone have any guesses as to what each cam would get me as far as track times? Im hoping with a 224/230ish cam and electric wp, 1.6s, and reducing my race weight from 3225 to around 3000 with the stock rear and clutch to get into the mid 11s. I run ET streets, with a best 60 of 1.84 at 22psi. The motor has about 110k on it and about 160 passes at the track. Clutch is stock replacement with 10k on it, rest of car has 140k on it. Car is purely a toy, with the only street time it sees is the 30 minute ride to MIR, and emissions are not a problem because it will continue to be registered in WV.
Also, for those who had failures spinning a stock shortblock too high, what was the failure (knock? loss of oil pressure? or strait up BOOM!)
Anyone with a cheap cam or rrs or timing chain or anything also please pm me or post it.
Thanks
Old 07-24-2011, 07:15 PM
96lt1m6's Avatar
My buddy Mike did his bolt ons,cc503,springs,vg3600 and 3.42 gears..... Our DA was terrible at 4000' and received spark knock 6° from the header banging the floor
http://www.youtube.com/watch?v=N3xrM...e_gdata_player
Old 07-24-2011, 07:23 PM
97 SS LT1's Avatar
I have a 306 cam with worked stock heads. car was bone stock until 123000 mi. at 127000 i hit 6500 RPMs and spun the #8 bearing. I haven't shown any knock on mine. Last dyno was 365hp 355tq with a bad mis/cutout higher up...opti quit soon after!!
Old 07-24-2011, 07:27 PM
You hit 6500rpm the one time and it did that? Where was your peak on the dyno, I thought that cam didnt peak until 6500?
Old 07-24-2011, 07:58 PM
GREGG 97Z's Avatar
Sone 4:10's and a stronger clutch would really help you launching. I ran a best of 12.01 @ 115 with the hotcam kit and stock heads at that time, plus pretty much all boltons. Add those 3 things and I'm pretty sure you could hit an 11.
Old 07-24-2011, 08:04 PM
z_speedfreak's Avatar
+ some LCA relo's for a small gain and smaller price
Old 07-24-2011, 08:43 PM
"I MAID THEESE"
Mavn's Avatar
I want to do a cam swap on my auto lt1.. If I did all boltons plus a 3000 stall and a hot cam kit. Would I be able to outrun the new 2010-2011 ss camaros? And would my transmission hold the power? Thanks!!
Old 07-24-2011, 09:08 PM
I have zero spinning or wheelhop issues off the line, my slow 60s are just a result of me babying my 10 bolt by slipping the clutch and waiting for there to be pressure on the rear gears before dumping the clutch. What was your 60 on your 12.01 run and your race weight?
Old 07-24-2011, 11:57 PM
ProTreeRacing's Avatar
cc306 with boltons we made 368/370 with a 6 speed and 330hp with an auto. 6 speed car would go 12.30 at 115, auto car went a 11.8 @112
auto with a 150 shot went a 10.5 @128
Old 07-25-2011, 12:20 AM
Lawhead's Avatar
God all them CC306 haters have a lil something read in this thread
Old 07-25-2011, 12:47 AM
96lt1m6's Avatar
Thats for sure!
Old 07-25-2011, 02:19 AM
itSSlowZ28's Avatar
How high were you guys spinning that motor?
That's what I was thinking!
Old 07-25-2011, 05:47 AM
Rob
Rob's Avatar
HOT cam here. The usual bolt ons but with SLP dual cat shorties into stock y-pipe into a Borla/SLP cat back, had to keep it so I could pass emissions. 4.10, M6, Hotchkis panhard bar, tubular LCA's, with Nitto DR's
Original engine went 12.45@111. New crate engine with everything swapped over, 12.44@111. Best runs at MIR back in '99 and '00, respectively. Pickup fell off and spun the #4 rod bearing, replaced under warranty. Shifting at 6300.
Old 07-25-2011, 06:38 AM
GREGG 97Z's Avatar
12.01 @115 1.75 60'. 3450 race weight.
I know what you mean about the 10 bolt. I ran a stock style clutch up until I got the 12 bolt.
Old 07-25-2011, 06:41 AM
I dont want this thread to turn into a 306 debate, but it looks like the docile hotcam traps the same as the dyno queen 306...where are yall with the 306 shifting?
Anyone have any times/shift points/numbers on a 503, 305, XE230/236, 847 or crane 227 or any other cam only cars?
GREGG 97Z, those are really nice numbers
Old 07-25-2011, 06:50 AM
RamAir95TA's Avatar
You may want to peruse the few stickies (Dyno esp) at the top of the main page - you'll find what you're looking for.
Old 07-25-2011, 07:57 AM
I've read through that and there are some valid examples there but I know not everyone posts their times in there, and nobody posts their shift points or carnage
Old 07-25-2011, 08:20 AM
green94z's Avatar
[QUOTE=itSSlowZ28;15192317]How high were you guys spinning that motor?
The auto was my car. We were spinning to 7000
Old 07-25-2011, 08:35 AM
chas010's Avatar
cc503 shifted at 6200 rpms auto z28 with 3200 vig (converters fs!) and 3.73 gears
1.675 60ft 11.894 113.4
1.719 60ft 11.975 113.1
Old 07-25-2011, 08:42 AM
Holy ***** green94z! How long did it last for?
Quick Reply: LT1 "cam only" dyno results/track numbers?
