Lt1+th400=?
Old 08-09-2011, 01:13 AM
IslandParkRacing's Avatar
Default Lt1+th400=?
So i popped my 4l60e and i have a th400 just waiting to go in. What do i need for this swap? i have the 4" tailshaft. How hard is it to do this and what is needed?
Old 08-09-2011, 01:23 AM
Big Al's Avatar
Cross member, way to mount the torque arm and a different drive shaft. Spohn makes a combination cross member, torque arm mount and drive shaft loop. UMI has various mounts too.
Al 95 Z28, TH400, S60
Old 08-09-2011, 08:13 AM
quik95lt1's Avatar
fyi just looking at your mod list the car will more than likely slow down with the th400 in it......
Old 08-09-2011, 08:57 AM
UMI Performance's Avatar
Like Al mentioned for mounting it you need a cross member.
If you have a stock torque arm you would like to use or already have an aftermarket torque arm that mounts to the transmission this torque arm relocation kit would be good- www.umiperformance.com/2224
It mounts a TH400 to the 93-97 chassis while also supplying a mount for the torque arm which the TH400 wouldn't have.
If I can help any please ask. Thank you!
Ryan
Old 08-09-2011, 10:54 AM
SS MPSTR's Avatar
I used the BMR mount, but the UMI unit looks nice too.
The TH400 is a power-robbing trans - don't get discouraged when the car slows a bit.
Old 08-09-2011, 11:09 AM
I'm not worried about power robbing because now with the TH400 the car will have nitrous on it now. But what size tailshaft do i need to be able to use the stock driveshaft? what about speedo? I'm am going to make my own crossmember and torque arm mount. i do have an aftermarket one to go in. But as long as it will bolt up and the TH400 converter will work im part of the way there. What about the shifter?
Old 08-09-2011, 12:41 PM
Big Al's Avatar
Since most real drag racing has turned to "dial your ET," the benefits of the 400 outweigh the tiny amount you'll give up in ET. A good driver with a 60's close ratio 4 speed and the right rear gear will beat any automatic in the same car if it's slower than 10.50. So what? You use an automatic and dial your ET and be more consistent. The 400 is about the best automatic transmission ever put in a normal car.
Just my opinion after 49 years of drag racing.
Al 62 Chevy II TH400, 73 Nova TH350, 86 Mustang C4, 95 Z28 TH400, 74 Z28 Powerglide, 2002 Z28 6 speed....
Old 08-09-2011, 12:48 PM
SS MPSTR's Avatar
I realize that, but the car now runs a 13.7. With the Th400 and nothing else changed, is will be slower - that's a fact. Will it be consistent? Of course it will be. Repeatability is king in bracket racing.
Old 08-09-2011, 12:58 PM
quik95lt1's Avatar
very true........driver and car is what wins races........you need both or you dont have anything........i had a run with my car last year one weekend......ran 10.41-10.43 all day......never moved...........i cleaned out the brackets that day
Old 08-09-2011, 01:55 PM
So will the stock driveshaft work? or no? VSS? Shifter?
Old 08-09-2011, 02:02 PM
SS MPSTR's Avatar
I had to get a new DS, the VSS from an S10 (IIRC) works, and I use a Pro Action Cheetah shifter in my modified console.
Old 08-10-2011, 12:34 PM
What is the length of your driveshaft? i have one that is currently in the car and one that was with the th400.
Old 08-12-2011, 12:50 PM
Whats the overall length of the 4l60e?
Old 08-12-2011, 08:14 PM
GREGG 97Z's Avatar
I have that Spohn combo TA, its a great piece. Its nice to take the load of the trans especially at the track. It also makes trans removal a much simpler job not having to mess with that pita stock TA mounting bracket.
Quick Reply: Lt1+th400=?
