93 lt1 into a 95
93 lt1 into a 95
Ok guys I'm kinda of new to the lt1 stuff. Any help would be appreciated. I picked up a 93 z28 m6 a while back with the plans of building a track car with a lsx and th400. I just recently picked up a 95 trans am roller for parts it had and to swap the 93 over to it. Looking over both cars it looks pretty straight forward. Looks as if I can pull the engine harness from the kick panel and install the 93 wiring. All the plugs are the same with exception of the 93 having a few less wires. Am I overlooking anything? Or do I need to repin or add any other wiring?
We put a 93 TA Lt1 into a 95 v6 Camaro body. Should just be plug and play. The only issue we ran into is that we had to put a switch in the fuel pump relay circuit because for some reason it didn't want to send power to the relay.
you will have to repin a few connectors. Its not difficult. Here is a link from shoebox's site. http://shbox.com/1/harness_connector_faces.htm
There are tabs at the bottom of the screen for the different connectors. His site is very helpful.
Did u miss the part where he's putting a 93 motor in a 95 roller? He says he Lacks a PCM and a maf, well then.. I have a 95 pcm available. And swapping the 93's wiring over would be more work and less tunable.
he would still need maf. he already has a 93 pcm so why not just repin the 3 connectors and use it. He is looking for cheap as well.
