Errr, was this suppose to go back on?
Old 08-24-2011, 07:52 PM
02v8ta's Avatar
Default Errr, was this suppose to go back on?
Not my photo but that's the part i found at my buddy's today. haha?
Old 08-24-2011, 08:09 PM
camar0corey's Avatar
Non-essential.
95sscamaro's Avatar
only if you want it on
Old 08-24-2011, 08:46 PM
Rob94hawk's Avatar
Isn't that the tranny crossmember?
Old 08-24-2011, 08:49 PM
Camaro350Z28's Avatar
nah its just like a tunnel brace. mine got removed to setup my true duals
Old 08-24-2011, 08:50 PM
LSWHO's Avatar
Mine may be in the trash. Dunno if I still have it. If you want it on it's as hard as jacking up the car and doing the 4 bolts.
Old 08-24-2011, 08:54 PM
Rob94hawk's Avatar
Is it for frame support? If so it might be a good idea for me to put it back on since I have t-tops.
Old 08-24-2011, 09:20 PM
Midnite Magic's Avatar
Not a big deal, they usually vibrate on the exhaust anyways
Old 08-24-2011, 09:22 PM
RamAir95TA's Avatar
Called the g-load brace, it doesn't do much. Mine has been off for 10 years.
Old 08-24-2011, 11:27 PM
02v8ta's Avatar
Thank you everyone! I do remember now it not bolting back up properly because of my y pipe being in the way so was hoping/assuming it wasn't an important piece.
Old 08-25-2011, 12:22 AM
nah youre fine
Old 08-25-2011, 12:54 AM
jester1614's Avatar
isnt the second part the rear main seal housing?
Old 08-25-2011, 12:59 AM
the_merv's Avatar
^Yes.
Originally Posted by 02v8ta
That's the Bracket for the Spark Plug Fluid Resevoir.
Old 08-25-2011, 09:03 AM
That's MISTER MODERATOR
Paul Bell's Avatar
no, no, NO! It's the muffler bearing grease holder thingy bracket!
I do like the burnout mark on the tile floor under the brace.
I think the tunnel brace should not only be retained, it should be upgraded to one of the much stronger ones on the aftermarket. GM would NOT have designed, made and installed one on every single F-body if they didn't think it was needed.
Old 08-25-2011, 11:04 AM
355z28's Avatar
I got rid of mine for a lakewood drive shaft loop.
Old 08-25-2011, 11:45 AM
guppymech's Avatar
I just put one on my car also. It's well engineered and made in the USA to boot!
Old 08-25-2011, 11:56 AM
Village Troll
SS RRR's Avatar
Originally Posted by Paul Bell
I see your tunnel brace and raise you one:
Old 08-25-2011, 09:23 PM
Paul Bell's Avatar
Oh yeah, that's cool too. I had the same setup (with the flat bar without the LT drop) but the loop was in the way of my new exhaust. A few skilled swipes with the sazall and the loop was gone.
Old 08-26-2011, 10:03 AM
Ugh, that's just a ton of bang and clang posted above. I can't believe I ran a short torque arm for as many years as I did. Went back to a full length with no regrets.
Old 08-26-2011, 10:11 AM
LT1FirebirdSLP's Avatar
Wow, totally appears to be a transmission crossmember. Ya might need it... just sayin'.
Quick Reply: Errr, was this suppose to go back on?
