Z28/ trans am lt1 casting #'s???
Old 08-25-2011, 01:21 PM
LTX_OUTLAW's Avatar
Default Z28/ trans am lt1 casting #'s???
Hey guys i was at the local salvage yard and i came across what appeared to be a lt1 short block ($125) i looked on the back of the block for the casting numbers this is what i got???
Rear stamped: Gm 5.7l6 sgi 10125327
left/right side has stamped 327
up front top has stamped v0621whk by the timing chain cover
it would be a great if you guys can help me out and make sure this is a legit lt1 for a z28/ trans am not the caprice engine thx
Old 08-25-2011, 01:27 PM
RamAir95TA's Avatar
That's an LT1 block.
Old 08-25-2011, 01:29 PM
CamaroZGuy's Avatar
yes, that is a LT1 block. the blocks where the same, it was the top ends that where different.
Old 08-25-2011, 01:40 PM
LTX_OUTLAW's Avatar
Ok change number 2 with a lil bit better light and the help of the wife this is the # 12125327 but to be on the safe side you guys said that only the top ends were diff?
Old 08-25-2011, 03:47 PM
96TransAmboosted's Avatar
Iron vs aluminum is the diffrence
Old 08-25-2011, 03:49 PM
qc97z's Avatar
Yes, that is an LT1 block.
Camaro/Firebird/Corvette LT1's have aluminum heads.
Caprice/Impala have iron heads.
Old 08-25-2011, 05:01 PM
LTX_OUTLAW's Avatar
Hey thx guys
Old 08-25-2011, 06:34 PM
outlaw you pm me but it says you dont accept PM. whats that about?
Old 08-27-2011, 03:39 PM
http://www.chevy-camaro.com/chevy-ca...es.asp?group=6
http://www.hpsalvage.com/lt1.htm
These links might help you out Bro. If you need anything else just let me know
Old 08-27-2011, 11:27 PM
LTX_OUTLAW's Avatar
just what i was looking for thx boosted
Old 08-28-2011, 12:56 AM
No problem
Old 08-28-2011, 02:22 AM
jester1614's Avatar
and iirc the cam was slightly different between the iron headed and aluminum headed blocks
Old 08-28-2011, 07:19 AM
96capricemgr's Avatar
The cam was slightly different but by all accounts the b-body one made better lowend and in bolton form they make similar peak numbers which would seem to suggest if anything the f-body cam was the one compromised. Maybe to keep your POS axle alive.
Quick Reply: Z28/ trans am lt1 casting #'s???
