383 build..what injectors?
I freshened up my 383 with new heads and ported intake and I'm wondering if my 30# injectors will be enough. If not, what's everyone running?
Sweet! Hopefully I can get this beast started sometime this week since everything is back in and just needs hooked up. This is my first actual performance head swap and I'm curious as to what type of power it'll put down.
30's will probably work depending on what it actually makes for hp.........like joe said just monitor the DC% if it goes over 90 you are pushing your luck
my old 355 made about 500fwhp and it ran on 30's at about 87% DC......so you should be able to make around 525ish with them.........
my 385 maxed out a set of 48's.............like i said matters on the power it actually makes.....
Hopefully my 42#s will be enough for my 383, with maybe a small bump in line pressure.
i went with a set of the low impedance 65's from FAST now.......so i can run a 10% oxygenated fuel and still have plenty of headroom at 43.5 PSI
