Installing engine through the top. How much can be bolted on?
Plan is motor's going in tomorrow. The BMR k-frame is already in. Question is, is it a possibility to install the engine with the serpentine belt system (minus the AC) through the top?
Obviously the headers are a no go but I'd like to make sure the accesory belt lines up with the new Fluidampr.
It can go in with the opti and hub on but I had to extend my boom on the cherry picker and I used the happy hooker lifting plate with a big hook and short chain out of the boom and turned the engine to the passenger side when going in. I also have a moroso pan on it. car was on the ground, no jack. I do say it is a hold your breath and pray situation when I use the happy hooker though lol. This pick was of the first time it went in. after head gaskets failed and it went back in the second time I did it with the opti and hub both on all by my self. I think I could even get it in and out with the water pump on but it may be a lot tighter squeez. no way to do it with Acc's on or even the damper for that matter.
Put mine in complete, everything except the exhaust. Balancer, waterpump, intake and all. Did not have the bracket that holds the alternator, power steering pump and AC. And no torque converter, but the flex plate was on. I even had the starter on but had to take it off.
Al 95 Z28
Al 95 Z28
It poors out because it fills the vally and runs down the timing chain. Primming the oil system again is not going to show you if you have leaks in seals, only if something was missed like an oil passage unplugged or fitting not on. Untill the engine gets up to temp and is running you wont know if seals and what have you are gonna leak. I will tell you right now if you have a groove on the water pump drive where it contacts the seal in the timing cover...its gonna leak. This is the only oil leak I have on my fresh 383 and it is driving me nuts because I know I have to tear the entire fron of the engine apart to do it.
LMAO! I still can. It's only the k-frame and a-arms that's bolted up. What's another 10 bolts and another 2 hours of my time. The reason why I'm doing it this way is because I need the engine weight to compress the springs to attatch the brake spindles to the upper a-arm.
