My F-1A Build
Old 09-14-2011, 05:36 PM
Sc0tt30's Avatar
Default My F-1A Build
Well UPS was nice today and delivered my heads and cam from Advanced Induction and here are the heads. Now just waiting on the rotating assembly.
Old 09-14-2011, 05:38 PM
alexcoreas's Avatar
How much was the complete H/C package?
Old 09-14-2011, 05:40 PM
Sc0tt30's Avatar
Since i included new pushrods with AI it was 3k total
Old 09-14-2011, 05:46 PM
alexcoreas's Avatar
I will be following this thread.... pretty glad you started this BC I'm actually going this route..... but I'm still working my way to the front of the car...
Is this going to be an all out drag build????
Old 09-14-2011, 05:49 PM
alexcoreas's Avatar
Is their a big advantage going trick flow? Rather then porting the stockers?
Old 09-14-2011, 05:53 PM
Sc0tt30's Avatar
I don't plan on it being just drag only. I still want to be able to drive it on occasion on the street.
I already have the rear end upgraded and suspension upgraded so that was done. I am just upgraded the bottom end, heads, cam, fuel and transmission
I am going to use a front mount intercooler for the procharger and run meth as well. I am going to start with 15lbs of boost and see what it puts down. I went with a aggressive cam that is 23x/24x.
Old 09-14-2011, 05:59 PM
alexcoreas's Avatar
Subscribed
Old 09-14-2011, 06:00 PM
Camaroking1996's Avatar
What bottom end parts are you using.
Old 09-14-2011, 06:02 PM
Sc0tt30's Avatar
AI said i could use their 200cc lt1 and made the power i am looking for. It depends on different factors to determine if trick flow heads are a bigger advantage. I could of most likely went with the 200cc lt1 and been fine but choose to go with the trick flow heads.
Sc0tt30's Avatar
Callies Dragonslayer crank, Compstar rods and Diamond pistons
Old 09-14-2011, 06:03 PM
Blackbirdws6's Avatar
I see a lot of power in your future.... Any more pics of the shiny parts? You giving me a small case of deja vu.
Old 09-14-2011, 06:10 PM
Sc0tt30's Avatar
Sure i do. I figured you might say that as well since you just did your build not too long ago. I have read your thread a couple times as well just to gain some more knowledge.
Old 09-14-2011, 06:50 PM
Mmm. Very nice. Make sure to double check the pulley sizes. Based on what I received from Procharger, I would have overspun the F-1A by 5,000 rpm . Would have been an interesting first dyno pull.
Old 09-14-2011, 07:09 PM
Sc0tt30's Avatar
Thanks! That would not have been a good first pull at all. Thanks for the reminder to double check the sizes. I already know i need to get a 4.25 pulley and take off the 4.50 pulley that i originally went with.
Old 09-14-2011, 08:53 PM
flyinZ's Avatar
Ah, thats gonna be a fun build. Your somewhat close to me, Id like to come see that bad-boy run.
Old 09-14-2011, 09:17 PM
hvyss's Avatar
Sweet. Can't go wrong with AI heads and cams. Love mine.
Old 09-14-2011, 11:09 PM
Sc0tt30's Avatar
I'm sure we could do that once I'm all done. How far are you away?
I have heard great things about AI so I'm sure the heads/cam will be great.
Old 09-15-2011, 12:27 AM
Moderator
BizZzatch350's Avatar
Cool set up, very pricey and bad *** set up to do any car, let alone an LT1
Old 09-15-2011, 09:47 AM
Sc0tt30's Avatar
Thanks!! I am hoping it will put down some nice numbers. You're right about the cost. I stopped keeping track how much I spent. I just know it's alot.
Old 09-15-2011, 09:59 AM
SRZ
SRZ's Avatar
Nice supporting cast. Look forward to seeing some numbers in the future. Good to see some hardcore LTx guys keeping the torch lit.
Quick Reply: My F-1A Build
