air conditiong vents
Old 09-14-2011, 09:49 PM
chris95lt1ta's Avatar
Default air conditiong vents
My air conditioning is blowing extremely cold but only through the foot vents and the windshield defrost vent. I just need to know the name of the part to fix this??? Ps. My vacuum lines are fine behind the hvac.
Old 09-14-2011, 10:35 PM
Formula413's Avatar
So that little vacuum T by the evaporator box isn't broken? That's the most common failure point. What you are describing is exactly what happen when the controls lose vacuum. Can you check if there is vacuum at the controls?
Old 09-14-2011, 10:50 PM
On the selector switch I can move it freely and the vacuum is fine but it will not switch from where it is blowing out pf. It doesn't matter what control I switch it too. Hope that helps a little big better.
Old 09-15-2011, 05:37 AM
RamAir95TA's Avatar
You're positive you checked your vacuum lines coming from the engine (passenger side intake manifold)?
Old 09-15-2011, 06:34 AM
shbox's Avatar
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
Quick Reply: air conditiong vents
