V6 shifter cable
Old 09-17-2011, 06:27 PM
shix's Avatar
Default V6 shifter cable
Anyone know if the shifter cable off of a v6 a4 will work for an lt1 a4?
Old 09-17-2011, 08:58 PM
shbox's Avatar
I can't find anything that says there is a difference.
Old 09-17-2011, 11:20 PM
shix's Avatar
im having a problem adjusting it. I am following your site but the cable doesn't really move in the housing as the directions imply. I can match the lever to the shifter but then it feels like there is no dettent for 1st and the shifter feels really sloppy. Any ideas?
Old 09-18-2011, 08:18 AM
shbox's Avatar
Are you sure you are getting the lock button pushed up? There are some little teeth in the end of the cable housing that it locks to. That is where it should slide.
Old 09-18-2011, 10:19 AM
shix's Avatar
I pulled the locking tab all the way out just to make sure. It still doesn't want to move. Is there anything up by the shifter that it could be hung up on?
Old 09-18-2011, 09:23 PM
shbox's Avatar
If there is any slack in the housing, I would think it would move.
Old 09-22-2011, 11:23 PM
shix's Avatar
found that the plastic housing surrounding the cable pulled out of the clip inside the car that holds the rod in place. I hope that makes sense. Is it fixable or do i need a new cable. I think the trans got hung up on the cable when i dropped the enging/trans out to put my lt1 in.
Old 09-23-2011, 01:46 AM
the_merv's Avatar
You might have stretched it..you can get them for like $10 at the junkyard..
Old 09-23-2011, 02:19 PM
sweetbmxrider's Avatar
My car has a v6 cable but no v6 motor.
Quick Reply: V6 shifter cable
