1995 camaro Z-28 what is the right code scanner to use?
Old 09-19-2011, 04:40 PM
95_Z-28_runner's Avatar
Default 1995 camaro Z-28 what is the right code scanner to use?
i have a 1995 camaro Z-28 with ses light and dual fans running but runs and drives great no problems or bad gas milage. the only symtom i see is sometimes a hard start up. i have done a full tune up replaced the coil and opti spark and changed the fuel filter and fuel pump three months ago before this problem. im thinking its the fuel pressure regulator or a leaking injector. so it leads me to the qestion which code scanner will work i have a OBD2 plug in with a OBD1 computer? what scanner will work for this car?
thanks alot,
Old 09-19-2011, 04:44 PM
RamAir95TA's Avatar
An interface cable, a cheap laptop, and free diagnostic software like Datamaster and Freescan. By far the most versatile, flexible, and reliable. If you're smart about it you can get the whole setup for under $100.
Old 09-19-2011, 04:48 PM
do you know why they put that weird connector in there? was it put in production beacuse of the 1996 OBD2 comming out the next year?
Old 09-19-2011, 04:51 PM
RamAir95TA's Avatar
Doesn't matter why they put it in...it's there and us 95s have to deal with it.
Probably something with the OBDII I'm sure.
would you happen to have the link for the software? i have down loaded tuner pro will that work?
Old 09-19-2011, 04:53 PM
RamAir95TA's Avatar
www.ttspowersystems.com
www.andywhittaker.com
Old 09-19-2011, 08:03 PM
shbox's Avatar
Yes, that would work fine. Get a cable and go!
Quick Reply: 1995 camaro Z-28 what is the right code scanner to use?
