lt1 timing chain sugestions
the stock replacement from gm is like 250... is there anything else i can do that is cheaper... i dont wanna spend 250 on a stinkin chain and gears.... i have a stretched chain that needs replacement.... so im guessing i need gears and all... part numbers would help
thanks
thanks
A stock replacement chain and sprockets should be about half that. What part numbers are you looking at, and where are you sourcing them from? Check www.shbox.com for the correct p/ns.
Don't forget that you need to change the sprockets too. Doesn't make sense to put a new chain on worn sprockets.
If you need the spline drive opti style, Lunati makes one. It is just over $100, but it is not a roller chain. I ordered one for my build and took a look at it. It is a heavy-duty piece but I then went with a double roller and a vented opti.
http://www.summitracing.com/parts/LUN-93094/
The Lunati 93094 looks just like a GM stock set. It even has the GM number on the cam gear. But that won't fit your car, if it is a 1995. The Cloyes 3039 will.
