Just finished my first engine romoval out the bottom
Never will I ever go that route again by myself, and I have a lift. If I have to do another by myself I will def do it out the top.
Care to explain what went so horribly wrong? My guess is you did something wrong, didn't have the right tools, or didn't have enough information to help you along the way. I know at least 5 people who have done both who prefer out-the-bottom over out-the-top.
Also, if this was your first ever engine removal and you have no experience pulling it out the top, then how do you know out the top would be easier?
No man not my first I have a 96 TA that I removed and built out the top. Really and truley I went about it without doing much research, the car I pulled it out of I am trading the labor on removing the engine and tranny for the body to start another project. Like I said probably never by myself again but if someone else come along to help with experiece maybe. Any tips you would like to share I will surely take notes on.
Andrew
Andrew
putting it back in will suck 10 times more
edit: ah you posted saying it wont be going back in. I was just going off of the known fact its easier to take something apart then put it back together lol.
I have read that before but its been a while. Pretty much winged it, I didn't have any real hang ups just seemed like a lot of work and now I have to go put the kmember back in to get it of my lift. I guess some of it has to do with having an engine and tranny hanging in the air and taking all the other stuff a loose just to remove an engine. Hell maybe I'm just grumpy right now but as of know I would rather go out the top.
Truthfully you set yourself up for failure by not doing your homework. In terms of general automotive practices removing an engine from the bottom is fairly uncommon and is often approached with a bit of skepticism. If you aren't familiar with it during the process it is easy to throw in the towel because you're simply too uninformed to get the job done in the potential timeframe the out-the-bottom method allows.
Better luck next time I suppose!
Yea your definatly right I should have atleast refreshed myself before I started, any way I wish I had the cash to just buy yours but down here in Bama it seems we are all broke lol, the car I pulled the engine and tranny out of started out life almost identical to yours a green 95 TA but has been wrecked in the past and the rear was fixed with firebird parts so the guy that had it was going to part it and scrap it so I figured what the hell whats another project, but anyways thanks for the post.
Andrew
Andrew
That could just boil down to patience and experience. I just dropped mine out the bottom in my tiny garage with a cherry picker. Granted it's my 3rd time dropping an LT1 out the bottom, and I can see it being harder if you don't know what you're doing. Whatever works better for you though.
It's like sex. Some like it on top, others like it IN the bottom. lmao sorry couldn't help it. For me it the fact that they don't build a freaking multicar garage in Florida where I buy deep enough to put the car and the whole frontend in. I could put it next to it but that’s my work space. And the other bay is the wifey's. It gets thrown out if it enters that space. As proven by the missing connecting rods and pistons from an old gen 1 small block I had. (Perfect shape) It gets rather comical.
Ive pulled them out of the top countless times and out the bottom a couple of times. If you don;t have a lift it is dangerout IMO to drop it out the bottom. Ive made some plates that bolt on the 2 center exhaust bolt holes on the head and it isnt to bad. Plus there is less mess when out the top due to not breaking open the brake system. And like said, if you have to put it back togather to get it off the lift before you ban reinstall the engine, that just sux.
Does the trans have to come out with the engine, when pulling out the top?
I kinda looked down there yesterday, and it doesn't seem like the bolts that mate the engine and trans are accessible.
I'm working on pulling out the bottom right now, but I do have limited space, so that makes me wonder.
the bolts are accessible.. support *** end of tranny, drop tranny mount, lower tranny *** untill its off the jack.. take out top bolts, jack tranny back up, remove rest of bolts... too easy. need about 6 long extensions and a good swivel and it is a cake walk.... Ive got air tools so its super easy to do...
