Where are you guys mounting crank trigger pick-ups?? Where should I put the 0'magnet?
Going with an msd crank trigger pickup kit but have never mounted one. Where are those of you running the flying magnet mounting it? I obviously don't have an opti.
I am ordering the ATI damper shell with magnets in it but don't know where I should place the magnets in relation to tdc etc? This is a corvette lt4 so my damper/pulley are one piece.
Thoughts? This is running a gen 7 dfi standalone.
Looks like you both have different accessories than me. Is that a custom bracket/plate that mounts the ps or vaccum pump down low on the right? In a Y body there isnt anything down there on that side. ANy ideas on where I can mount the pickup without having such a bracket?
The bolt holes used on both of those setups are on the stock block or at least one of them is. The reluctor wheel looks to be bolted to the out side of the damper with longer bolts through to the hub. Once you mock up the Wheel on the damper you should be able to mount the pickup bracket using the bolt holes on the block and just space to where it needs to be. I think the trick to the reluctor wheel mounting is going to be using an ATI or some damper that is flush so you don’t bend or deflect the reluctor wheel when you torque it all down.
