Is it worth putting a cam in?
Old 09-21-2011, 03:10 PM
Silver94LT1's Avatar
Default Is it worth putting a cam in?
My 94 z28 just hit 93000 miles and I wanted to know if this is too many miles to put a cam in or should I rebuild the motor? The motor still runs strong and I would be looking into putting in a mild cam in it.
Old 09-21-2011, 03:23 PM
quik95lt1's Avatar
if it was mainained you should be fine
Old 09-21-2011, 04:17 PM
ahritchie's Avatar
Yes...you're just getting it broken in for a LT1 if it's been maintained.
Old 09-21-2011, 04:22 PM
Thanks! I had the heads redone a year ago so I guess I will be fine
Old 09-21-2011, 04:36 PM
ahritchie's Avatar
Just upgrade the springs and get roller rockers too.
Old 09-21-2011, 04:44 PM
defaultexistence's Avatar
Lol gawd, mines at 193,000
Old 09-21-2011, 04:49 PM
robmnrd's Avatar
Did my H/C/I at 160000 miles. Cylinders looked good, bearings looked much better than you'd expect for the mileage (Not quite like new, but I mean come on...lol), and oil pressure was still way above GMs "safe minimum". If you're still making plenty of power and there isn't anything jumping out at you saying there's an issue, you'll be totally fine with a cam swap.
Old 09-21-2011, 06:01 PM
Zlow28's Avatar
197,000
Old 09-21-2011, 07:22 PM
190,000 and 160,000 wow! I think I should be fine then lol! You guys make my motor look brand new!
Old 09-21-2011, 10:10 PM
rich5368's Avatar
Only 93k. Shoot it's still got the new car smell under the hood
Old 09-22-2011, 02:13 AM
meine96ws6's Avatar
Mine woke up real nice after the baby cam went it..
Old 09-22-2011, 06:44 AM
pillarpod's Avatar
i did a H/C at 154k
Old 09-22-2011, 09:03 AM
on1wheel01's Avatar
Yea I'd say go for it. If shes been taken care of your good to go
Old 09-22-2011, 10:59 AM
Sounds good! Thanks for all the info guys! meine96ws6 what Cam did you go with? Is lloyd still donig H/C packages?
Old 09-22-2011, 11:44 AM
Village Troll
SS RRR's Avatar
You should be fine. Bearing failures after part of the engine has been opened up usually points to a sloppy/dirty/hurried (I'm sure many innuendos can be made from this) install.
Old 09-22-2011, 12:20 PM
SexyTransAm's Avatar
i didnt cam mine till 130000, cc503
Old 09-22-2011, 12:39 PM
alexcoreas's Avatar
I'm looking to do it at 88k miles since I'm broke lol
Old 09-22-2011, 01:05 PM
96TransAmboosted's Avatar
I would say if you pull the valve covers and intake and there is no sluge.... Cam it. If there is sluge don't.
Old 09-22-2011, 04:23 PM
hell if there is sluge keep pullin and rebuild
Quick Reply: Is it worth putting a cam in?
