Couple of questions
Couple of questions
Just a few questions for a newbie when it comes to the LT1. In regards to upgradability and efficiency, which is a better system for the LT1? Keep in mind tuning is no concern for me, because I have a relativaly cheap source to program the PCM. Is OBD I or OBD II better for the LT1?
Also, IIRC I read somewhere that a stock B-body LT1 redlines at about 5600 RPM mainly due to the rockers. What all do I need to do to the b-body LT1 to get it to go a little higher in the RPM range? And I'm not talking anything crazy like 7000 rpm, but between 6000-6200 or so would be nice.
Lastly, with full bolt ons (headers, 1.6 RR's, airfoil, 52mm TB, etc) what kinda of HP can I see from a b-body LT1? I know they are stock good for 260, but I'd REALLY like to see at least 300 from this engine if possible without totally tearing into it.
Thanks for the help everyone!
Cam determines rpm range. You can spin it more but it's not going to make any more power at 6200. full bolt-on's and tune should get you close to 300 but I don't know about changing the rockers on stock springs. That would be a good question for someone who has done it. Headers, CAI, exhaust, TB coolant Bypass, tune and a stall if you have an auto are great mods for these cars. OBD1 is easier to tune and to run data logs on. There are free data logging software and tune software for OBD1. OBD2 is expensive and PITA impo
