lt1 random misfire help
i was driving down the road and came to a stop at a light when leaving from the light the car had a real bad misfire so i pulled over popped the hood and it almost sounded like a knocking noise and wouldnt run worth a **** so i turned the car off let it sit for a second and started it again the knocking went away but the miss is still there popping threw the exhaust real bad when i rev it i got it home and pulled all the spark plugs the looked fine and visually checked the wires there fine also i had just replaced the opti about a month i need help on this asap....thanks
exhaust backfires, did you do a msd opti??? could be late ignition timing, burned/ bent exhaust valve, check compression on all cylinders, maybe an ICM? whyd you replace the opti? a knock is never good
the other opti i had went out and i replaced it with a accel when it idles down from when i rev it it backfires if i go drive it it spits and sputters at wot then cleans out
