LT1 after market cam check???
Old 10-17-2011, 03:45 PM
my number 1 hater's Avatar
Default LT1 after market cam check???
LT1 after market cam check? Found a few nice parts on the LT1 out of the red car this weekend. I can tell by the way the intake was painted the motor has been out. Can i put a dial guage on the pushrod side of the rocker arm and measure lift? At the very least, the lift should be different from a stock cam.
Old 10-17-2011, 03:49 PM
96capricemgr's Avatar
Would give you some clue but lifter bleeddown will lower the numbers below the actual lift of the cam.
Could get closer if you could put some very light springs in it to avoid the lifter bleed down.
Old 10-17-2011, 03:58 PM
Dang, thats no good.
Hey would you know if i pull the opti, is the cam snout marked?
Old 10-17-2011, 04:26 PM
draggin97s10's Avatar
nope, gotta yank the cam out.
Old 10-17-2011, 05:04 PM
nitrous2fast's Avatar
Just loosen the rocker until it gets slightly wiggly. Then put the dial gauge on. Measure a few times. Should be in the ball park.
Old 10-17-2011, 05:44 PM
Not a bad idea, Im thinking of pulling the intake and measure straight off the lifter.. That would get me a little closer..
Old 10-18-2011, 03:15 PM
UPDATE: pulled the intake, measured lift from the exhaust and intake lifter.... Found .523-.526 ish and .524-.526 ish. With that lift and the rockers being GM 1.6 that come with the HOT CAM kit... IM saying HOT CAM... woot woot
Old 10-18-2011, 03:23 PM
nice job!!
Old 10-18-2011, 03:31 PM
Thanks, I hope this helps other people. For a parts car i have been real lucky with parts.
Old 10-18-2011, 03:48 PM
https://ls1tech.com/forums/lt1-lt4-m...l#post15521566
link to the pics and parts i found so far. By the way i traded some paintball gear for this car...
Quick Reply: LT1 after market cam check???
