Waterpump Driveshaft Seals...discontinued
EDIT: I do not believe they are discontinued, must have been an error by the parts guy. The discontinued parts were Impala SS headgaskets.
So my engine is torn apart right now. I'm putting it back together, ordered up gaskets and seals.
12553792 Water Pump Driveshaft Seal has been discontinued.
What do I do? Can I reuse the originals? I've done a search on the Auto Zone website, and don't find anything.
It appears that the Fel Pro seal is the only remaining seal for us.
BTW, the Felpro set is the most economical way to get all the cover seals.
They look like a C/R or National brand seal. Take to an industrial seal or bearing supplier and they can match it up. Or measure the shaft size, OD and width of the seal and look it up on their web site.
I just saw a video of someone replacing the seal. The original seal has the part number which I couldn't read. If you have an original, please post the part number.
I had somewhat the same situation as wrd. I messed up the seal from the felpro kit and called the dealer for just the seal, they wanted $19. The kit from Napa for me was $8 with my student tech discount.. The part number for the seal it self is 10217886. That was the number off my original. (94 Formula)
If AC doesn't have one then lmk. I should have a brand new one somewhere laying around. Don't need it with an EWP, but the kit is still the best way to get the timing cover gasket and seals.
I assumed he was talking about the water pump drive " lip" seal. O-rings can be found anywhere. The original lip seal with the number 10217886 stamped on it seems to have been made for GM by National. It can be matched by the dimensions.
