95 LT1 swap into 94 camaro Q&A
95 camaro LT1 (got the harness and computer, T56) pulled motor and trans.
My car 94 Camaro LT1 T56
From the searches online this is what i have come up with. I should use the harness from my 94, get the plug off the 95's harness for the OPTI spark because its longer, there are 2 vac hoses, one goes to the air intake, WHERE does the other one go? Thats all i can find seems like there should be a knock sensor issue too.
If you can give me a run down on what i need to change/get/or might miss during the swap that would help.
Use your 94 engine harness and the 95s opti harness. No knock sensor change needed.
http://shbox.com/1/opti_vacuum_conn.jpg
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/ci/ci05.jpg
Bro you have your own SITE... Sweet there is a TON of info on there. Thanks
