Rotating assembly recommendations for 96 Corvette LT1
Old 10-21-2011, 08:25 PM
Hawk73ku's Avatar
Default Rotating assembly recommendations for 96 Corvette LT1
I'm a newbie and not much of a gearhead so I'm looking to expertise here. I'm also a bit intimidated by all the acronyms brandished so please be patient.
I spun a rod bearing in my 96 Corvette LT1 and have no choice but to replace the crank. I was content with stock performance so the repair goal is rebuild a solid unit at the least expense.
In reading about rotating assemblies I gather the 383 is more efficient in horsepower as well as fuel economy. Is this true?
If I were to go with a 383 rotating assembly I have the following questions:
1) Are there good kits where I don't have to figure out all the pieces I need? If so which kit(s) would you reccommend and where can I purchase?
2) What kind of costs are associated with prepping the block?
3) Do I need to bore the cylinders to accomodate new pistons & rings? If so to what spec?
4) Is it advisable to upgrade the cam as well? If so what are your reccommendations.
5) Is there anything else I can do to rebuild a solid unit? i.e. distributor, water pump, oil pump/cooling.
6) I have stock aluminum heads. Other than checking for warp and reseating valves should I consider anything else?
Old 10-21-2011, 08:54 PM
Lawhead's Avatar
If your not porting your heads go find another LT1 crank and use it
Shouldn't even consider more cubes unless you have a top end that will benefit from it plus the stock LT1 crank has a good rep for being stronger then most aftermarket cranks
Old 10-21-2011, 08:55 PM
96capricemgr's Avatar
If you were happy with stock performance I would just get a used stock crank. They are better than cast aftermarket and wont require a lot of other parts and machining.
Adding displacement without substantial cam and head upgrades as well as headers fuel injectors and all will be a complete wasted effort.
With bolton, heads and cam you can add a couple hundred HP to an LT1 before you need to start looking at more displacement.
Old 10-24-2011, 09:58 AM
Hawk73ku's Avatar
Not much luck finding a used crank so far. Does anyone have a source for a good stock crank?
Old 10-24-2011, 10:07 AM
KENS96M6's Avatar
I have a stock crank out of my 96.
Old 10-24-2011, 10:12 AM
Village Troll
SS RRR's Avatar
Did a shop tell you the crank was bad? In most cases the crank can be repaired.
Quick Reply: Rotating assembly recommendations for 96 Corvette LT1
