block ventalation questions for the pros
Restricted User
im in the middle of building a solid roller 383 and i am looking at maybe putting the pipes in the valley holes.
main thing i am asking about is using header evac system to create vacuum on the crankcase. anyone else using this setup on an lt1? also does anything need to be done with the pcv valve?
let me know your setups
first quesiton you need to ask your self is it a 1/4 mile only car or a car that will see street time...........when i built mine i passed on lifter valley vents because i do see some occcasional street use..........i want the oil dripping down on the cam and lifters to keep them lubed and cool..........if its a 1/4 drag motor only id for sure run the vents.......
as for the evap in the header again on a drag application it works well......just make sure you vent them BEHIND the O2's or you will have serious issues.......i passed on the evap system and went with a vacuum pump.......i can control the vacuum it pulls and i have vacuum all the time in the crank case instead of only high rpm WOT
I run the moroso crankcase evac kit on a non restrictive exhaust. It works fine on my street/strip car. For the record it doesn't vent into the exhaust, it siphons through the exhaust as the exhaust gas passes by. It uses a check valve system up to the breathers in my valve covers. I also kept in place the stock pcv system. I have seen this run on cars with a muffler but it won't pull as much vac as a non restrictive type. Mine are loud, you can def hear it whistle. almost sounds like a procharger when on the gas hard. I mounted the insertion tubes in the y pipe on each bank.
Restricted User
Thanks for the replies guys, it will see some strip time, I am running howards lifters. What is the normal cost of a vacuum pump setup? And did anyone see any gains from the header evac system? Is it a good idea to the the stock PVC valve in place?
