What size Cam can I upgrade to?
Old 10-30-2011, 05:08 PM
HarleyZ28's Avatar
Default What size Cam can I upgrade to?
Here is what is done to my motor as of now. I like the Hotcam, but I want something that puts down some more power, but still isn't horrible to drive on the street. What are my options with whats already done?
mildly ported & polished heads & intake (Flowed 249 intake/162 exhaust, 11:1 compression) Heads milled .010, .026" gaskets.
- Stock 63k mi bottom end LT1
- Manley 2.0 intake/1.60 exhaust valves, Crane 10308-1 spring kit,
- GMPP Hotcam
- GMPP 1.6 ratio aluminum roller rockers
- Comp Cams hardened pushrods
- Cloyes double roller timing chain
- Hypertech 160 deg t-stat
- CSI electric water pump
- March 25% underdrive pulley
- 1LE a/c delete pulley
- Lucas/Delphi 42 lbs / hr injectors
- Walbro 255 lph fuel pump
- MSD Blaster Coil, new MSD opti cap/rotor
- Taylor Spiro Pro 8mm wires, NGK TR55 plugs
Old 10-30-2011, 05:13 PM
draggin97s10's Avatar
id do like 228/236 at about 570ish on a 110.
Old 10-30-2011, 05:15 PM
HarleyZ28's Avatar
What kind of number gains could I expect with that?
Old 10-30-2011, 05:17 PM
Rob94hawk's Avatar
232/240 especially with your M6. But I'm a little bias.
Oh, IMO I would upgrade your rockers and springs with a more aggresive cam.
Edit: Do you have headers?
Old 10-30-2011, 08:21 PM
96capricemgr's Avatar
How does the car perform now?
Flow numbers are not everything but those are mighty low numbers for bigger valves.
If the car performs well though the flow numbers don't mean anything.
The GMPP rockers have a short slot which is going to be a potential problem with a modern cam with real lift.
Once the car starts making power you might find the TR55s a tad hot so consider a TR6 next time.
Old 10-30-2011, 09:44 PM
rich5368's Avatar
I'll be running a 224/234 with some pretty healthy lift, LE2s and 1.7 rr on a stock bottom end.
Quick Reply: What size Cam can I upgrade to?
