Clutch options?
Old 11-04-2011, 03:22 PM
camar0corey's Avatar
Default Clutch options?
So what is going on in the world with LT1 clutches these days? Is the Street Twin still the top dog?
I don't know what I want to do, the throwout bearing is about twice as loud as it was last month. Current setup is a full metallic six puck disc, modified Hays pressure plate, and SLP billet flywheel. The disc has about 30k on it now, not sure how long a metallic clutch is supposed to last. The flywheel has been surfaced twice, not sure how much has been taken off, being billet and all.
So I'm at the point where if I already have to drop the trans to take care of why ever the throwout bearing is rattling, I'm contemplating changing everything, thoughts?
Old 11-04-2011, 07:43 PM
95mysticta's Avatar
Im not sure what power level your at or how you intend to drive it. I had the Ram HDX with boltons and was great untill i put sticky tires on at the track and it took two outings to dust it. It was a great clutch though for the street at boltons level. Im running the Ram Powergrip and im pretty happy with it so far. A little more aggressive to be expected but nothing you couldnt drive on a DD basis just not stop and go rush hour. Comp Clutches are also making some great clutches, do a search on here theres been alot of discussion. If your at pushing the 400+rwhp and beat on it all the time i would look into the Spec 3 its a proven performer and if your 450+ id be looking into the Street Twin.
Old 11-04-2011, 07:51 PM
It's currently making 359rwhp/362tq, I also plan to hit it with a 200 shot through a Nitrous Outlet plate. Have a 12 bolt, drag wheel setup is 15x10 Draglites with Nitto 555r.
Yeah if I press the clutch pedal down 1/3-1/2 way the rattling stops. I know they always rattle but this has definitely increased in noise recently?
Old 11-04-2011, 08:06 PM
97REaper's Avatar
IF your on a budget the Competition Clutch Domestic Stage 2.5 - 2375 is a good clutch i like mine..
Old 11-04-2011, 08:45 PM
Badazz 97 TA's Avatar
What about the mcleod super street pro clutch? Anyone have experience with that one? Doing a 6 speed swap. Looking at all my options right now for lt1 clutches.
Old 11-04-2011, 08:57 PM
Hackscamaro's Avatar
im running competition clutch's stage 4. so far i really like the clutch has around 4 thousand on it. i havent really beat on it much did a couple burnouts to test the line lock and did a couple rolling start run up's. no dumps on it. holds well and im right around 400 or so as well. i ran specs stage 2 and didnt care for it. i also dd this car
Old 11-04-2011, 09:04 PM
6spd97ta's Avatar
I bought a street twin when my intake leaked and pissed oil on my clutch. This thing has roughly 30k on it and still grabs hard as hell. Never had a problem daily driving it or racing it. Only problem I've had is the slave leaks down internally and I can't seem to find a rebuild kit for it.
Old 11-04-2011, 11:46 PM
Sc0tt30's Avatar
I have used a few different Spec clutches and never had a issue with them. I just switched over to a McLeod Street Twin for my FI build.
Old 11-05-2011, 07:30 PM
lt1_2buku's Avatar
^^^^^ Glad to hear you say that.
Old 11-07-2011, 07:36 PM
Well I pulled the trigger on the street twin! AC said he didn't have to modify anything though, but I had seen threads from even 2010 about shaving something down for the clutch fork?
Did Mcleod fix this recently or something then?? Any install tips or things I need to watch out for that would be different from any other LT1 clutch?
I almost want to get the bellhousing while I am at it, but damn! $$$$$$$
Old 11-07-2011, 10:27 PM
2manycamaros's Avatar
i run a zoom kevlar in my lt1 and have no complaints at all very mild mannerd on the street and never had any slipping or anything when getting on it
Old 11-07-2011, 11:39 PM
FormulaJoe's Avatar
Same here! Got a couple thousand on it and going strong.
Quick Reply: Clutch options?
