94 vs 95 camshaft differences for opti swap
I have searched a pretty good bit trying to figure out if the nonvented optispark will work with the 95 model camshaft. I am rebuilding another engine for my 94 camaro with the nonvented opti which I just recently purchased and was wondering if the 95 camshaft will work with my opti. I know the dowel pins are different lengths and the 95 camshaft is supposed to have a bigger hole in the center which prevents the vented opti from working with the 94 model camshafts. I want to go with the 95 cam in case my opti goes out in the future so I can swap to the newer distributor but I want to use the nonvented one now since it's pretty much brand new.
Does anyone know if I can use the nonvented distributor by changing the length of the dowl pin in the 95 camshaft?
thanks in advance
thanks in advance
Let me get this straight i have a 93 and a 97 backup motor i wont be able to use a 93 fron cover or opti on the 97 motor when i build it to put it in? If that is so what else is not compatible from the 93? Sorry don't mean to hijack the thread.
