Is 7 quarts overfilling it for a Moroso 20185 pan?
Is 7 quarts too much for this Moroso oil pan? Just trying to figure out if I'm overfilling it since I still have this oil leak at the back of the engine somewhere. Thanx
http://www.summitracing.com/parts/MOR-20185/
That's MISTER MODERATOR
You should not be going by whatever anybody says to put in. You should fill the engine until the oil on the dipstick hits the top of the "full" mark. Then count how many quarts you put in. That's your number.
If you have an aftermarket oil cooler, you'll need to re-check the level after you've restarted the engine-then waited until it's shut down for a while.
Village Troll
Not sure about the Moroso pan, but the Canton 242t pan does not place the dipstick where it is accurate. It sits higher so if one were to fill up until the dipstick read full it would be overfilled and problems may start happening.
i dont see why you would need all that extra oil unless you have an hv pump. i bought mine for the windage screen and better oil control. i put the truck oil filter on it and put in 6 quarts. its still one more than stock, plus u bring the oil level away from the crank so u have even less chance of windage
The oil level when full does not change with regards to what pan, filter or cooler you use. The amount of oil you put in will vary but it needs to still get to the top of the "full" mark on the dipstick, which never changes it's position.
SO i might be confused? Say you use a cooler and i dont. Wouldnt the motor with the cooler take more oiL? I was trying to say what you said there
If you had the engine up in the air and removed the oil pan, the dipstick tube stays in the block and the dipstick gauge itself hangs down below the oil pan rail.
If you then installed a deeper oil pan, the dipstick stays where it was and you still need to fill the oil pan to the full mark on the stick.
The dipstick doesn't care if the oil pan holds five quarts or five gallons.
The "full" mark on the dipstick gauge is relative to the engine block, not the depth/capacity of the oil pan.
Keep in mind that a *real oil cooler will more than likely retain oil so when you first install an oil cooler, it's empty and the fill level needs to be checked after running the engine. After that, it'll retain oil and the fill after drain amount will be less.
*real oil cooler: One that has oil in it, not the wanna-be cooler GM used on LT1 cars.
Village Troll
I don't see what the confusion is here.
If you've filled the crankcase to a level above the windage tray, it's mark on the dipstick gauge will be above the full mark.
Regardless of oil pan used, the dipstick gauge does not move or change-and neither does the full oil level mark which is dictated by the engine, not the pan.
The oil level indicated on the stick has nothing to do with how much oil you've put into the oil pan to get to the full mark on the stick.
Village Troll
NEGATIVE. The full mark on the dipstick is below the windage tray.
