hp limit of factory block
Depends how much time you expect to to handle that power too, the guys making 600+fwhp NA have found bore shadowing and such evidence of undesired movement in cars that see a lot of passes. They sometimes crack the block deck too.
Yes in excess of 1000rwhp has been done, but I don't know how much it was honestly used.
Still no comment on how much use. Is it 20 passes on a 400 shot or 200 passes? Block decked? I have heard of some guys not decking the block on cars that see a LOT of passes because on blocks they did deck they ended up eventually cracking from bolt to bore.
Let's throw out overbore size? And did they sonic check a bunch of blocks to get a thick one or did they just use whatever was laying around?
My stock block was sonic checked, mf'ed and half filled. Ran 30 passes with the 300 shot (824 rwhp) ran 8.97. I have about 30 passes with the 350 shot (870 rwhp) and ran the 8.68. Hit the second stage only twice (guessing close to 1000rwhp) ran 157 mph in 102* heat. I am about to pull the engine to freshen it up because # 8 is down on compression. The cylinders will be checked again to make sure all is good. I will let you guys know what we find.
i am not sure were the edge is. there are a several guys running faster than us with a production block. our block was originally lt1 2 bolt. now it has splayed mains 2,3,4 and a billet front cap. i built this engine about 9 years ago and it has been progressively getting faster ever sense. best pass to date was a less than clean pass at 8.96 and 154 mph. one other thing to keep in mind is the type of power added used. i think the turbo combination would probably make the most power with the best reliability.
