Lt1 vavle adjustment*rookie at work*
Ltd1 engine.. I put new valves, srals, springs etc.. in the heads. Now its time to adjust them. Can anyone tell me what's the most accurate way of doing this. Hydrilic roller cam. And with the valves not set, will this cause the car to not start? Thanks
I used shbox's way to adjust them with the motor not running. My lifters bled down a bit so i adjusted them twice this way. The first time was actually pretty good using the spin technique.
Its a very simple procedure, just remember which valves are intake and which are exhaust as it can get confusing, i got lost halfway through once.
Hyrdraulic lifters offer a small margin of forgiveness making it pretty easy to ball park.
Dude has 1 post and can't spell. you think he/she has a clue who/what "shbox" is?
Learn valve lash procedure here:
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
I like to pre set them with engine off and then double check them with engine running. It can be a little messy but take your time and dont loose anything into the engine and dont hurt your self lol. If you do it with engine running get some card board or something to keep any oil off the exhaust while doing it this way.
Al 95 Z28
