94 pcm and 95 4l60e
94 and 95 PCMs are the same, but use different programming. Flash it with the year tune to accommodate the transmission used. IOW, if you want to use a 95 4L60E with 94 PCM, flash it with a 95 auto tune.
The pwm lock up converters have one more solenoid in the transmission. You will need to add in the wire from the trans to pcm. Then reflash to 95.
http://shbox.com/1/harness_connector_faces.htm pin U
http://shbox.com/1/1995_pcm_conn_d.jpg pin D6
