cc503 questions
cc503 questions
Hey guys with the rebuild I am swapping out the hotcam out for a cc503. Anyways I still have the stock 24lb injectors. Still on the stock pump with 157k. Will this be enough fuel to run it. Car will be broken in on the 24lb injectors and a stock obd1 computer. Then I am going to have it dyno tuned on the obd2 computer and I could swap injectors if I need to.
It is. I have a hotcam in the car now and its 12.3-12.8 at wide open throttle on a hotcam. Motor took a dump so swapping to the cam I wanted in the first place. I have a aem uego wide band on the car so I should be able to keep track of it.
