So I was doing a routine rear end fluid change and found this
Other than a loud pop/bang and the motor shutting off while I coasted to the side of the road, nope. At first I thought the motor let go, but I guess the rear locked up for a second killing the motor.
Sad thing is it happened with cruise control set at 80mph in 6th gear.
Village Troll
IIRC you were complaining about your OD gears with normal driving using 3.73's. In your case whatever one is stronger is irrelevant. If they're set up correctly on street tires they'll last forever. If it were my terd I'd go with 4.10's so I could use 5th and maybe even 6th in most cases. If you ever decide to go to the track, even launching softly you may get a better ET/MPH out of it...
