Eagle I-beam or Stock rod use?
I am building a 355 motor. I have stock rods with arp bolts installed that have just been redone. I also have eagle I-beam rods that are forged 5140 steel that are out of my 383 motor that broke the crank. which rod would be better to put in 355 with 11 to 1 compression engine. Running trick flow 62cc aluminum heads. Insight is most appreciated.
At 11 to 1 you are at the limit for the stock rods, but the Eagles need to be checked by a machine shop before you use them since they have been through a broken crank.
Ask them to check them for straightness and have the small and big end checked.
A crank breaking can do some weird things to rods.
Are the Eagle rods a 5.7 length or a 6 inch?
Andy
Andy
The Eagle 5140 rods are probably their SIR rods and are good for about 500 horsepower.....according to Eagle. The stock rods and ARP bolts are too. It's pretty much a lateral move and neither one is much better than the other. Your choice.
The eagle rods are all ready and better than stock , by the time ya install bolts and remachine the big ends and so on your into a brand new set of rods anyway !!! Why use stock when eagle is way better and has the a.r.p bolts in em
I like Eagle stuff and have used a lot of it with no failures but in this case, with limited funds, the stock rods would be a better choice. IMHO
