Good RR And Spring Set Up?
Old 01-04-2012, 03:02 AM
Ls1~Lover's Avatar
Default Good RR And Spring Set Up?
These Roller Rockers:
http://www.summitracing.com/parts/CMB-09-0017/?rtype=10
With These Springs:
http://www.carshopinc.com/product_in.../15859/10308-1
Any help would be great ( Would be with a CC306 Cam)
Old 01-04-2012, 05:38 AM
Stroked96Bowtie's Avatar
Sounds like you will potentially be putting a cam in the car (CC306). Rocker arm upgrade isnt going to hurt for sure and you don’t have to wait until you put a new cam in the car. You will see small gains in efficiency on a stock motor with this upgrade. Few points here 1) do your research! 2) Figure out your budget 3) Plan/map out changes to be made and STICK to it.
Don’t let the 'while I’m in here' get the best of you, it will drive your budget right out the door and down the street
Also, the link you posted for the rocker arms is for a Ford. Measure twice, cut once
