A couple of head questions
Im in the middle of building my LT1. I'm sure most of you have seen my build thread.
355, stock rods, stock crank, arp rod and main bolts
LE 226/232 .576 .571 110lsa
I really want to send my heads to AI but building my trans is more of a priority. I was looking to get them milled .020 and using the impala headgaskets.
Would I be ok not getting a valve job? I really don't want to port the heads till next winter at least. I think a valve jobs alone is ~$400 isn't it? I was hoping I could hold off on valve job and porting the heads until later on.
Suggestions/comments/opinions are greatly appreciated.
I have been working on this car for 2 years now, my goal is to have it running and presentable by June for a local meet and greet. I have a lot of paint and body work to do yet. Plus lots to buy. Build trans, exhaust, suspension, tires, plugs, wires, valve springs, headgaskets, motor mounts.
I haven't stumbled across that money tree yet
Of course you'll be OK not getting a valve job.
Wait until you get them ported to do it.
Just go with the proper spring setup, and it will run great with that cam for the time being, a lot stronger than stock!
You're smart putting the money into the trans at this point. It will need to be stout when you start hitting it with the higher rpm shifts
They are stock heads with ~130k on them.
I just don't know very much about heads. I already have comp 1.6 rr's, diamond chromoly pushrods (still plan on measuring before installation, just got a good deal on them) guideplates and 7/16" studs.
I was thinking of going with the Alex springs
I don't know if those Alex springs will be enough for that cam. Lloyd spec'd me a cam pretty close to yours and recommended at least comp 918s. I would double check. If I remember right the head gasket is part #5898. That's what I just ordered for my car anyway. I wound up going with the Patriot Gold Extreme springs.
The Alex springs are supposed to be fine but there is more to picking a spring than just valve lift. I would ask Lloyd since he designed the cam. The lobes may be too aggressive and you may need a spring with more pressure. You could list the advertised duration numbers and it would help guys on here to see how aggresive the lobes are if you don't want to contact Lloyd.
the alex springs are supposed to be fine but there is more to picking a spring than just valve lift. I would ask lloyd since he designed the cam. The lobes may be too aggressive and you may need a spring with more pressure. You could list the advertised duration numbers and it would help guys on here to see how aggresive the lobes are if you don't want to contact lloyd.
Link for head gasket. http://www.summitracing.com/parts/NAL-12553160/
If you go to the dealership tell them GM Performance 12553160 if the part number isn't exactly the same as 12553160 don't open them because they are probably stock lt1 gaskets. For some reason my dealership likes to cross reference the wrong part numbers.
