oil coming out of throttle body
i have a new motor thats got alot of oil blow by. nothing is cracked and pistons/rings are good as well as gaskets. its also good good vacuum. the instructions for my ring say to use a restrictor with 1/16 orifice in the fresh air inlet hose to remove all pressure from crankcase without pulling oil into the induction system. i was gonna try that but then seen a post about using a catch pan. idk what to do at this point
What sorry *** ring set did you get that is telling you to restrict the crankcase fresh air inlet? Do you see smoke if you pull the oil cap off with the engine running?
i dont knoe why u would say sorry *** ring set because the are TOTAL SEAL TRUE GAPLESS and it says so right on their instructions so thats what i am planning on doing.
If I were you, I'd take the engine apart and fix it. It is obviously not working right. The Mexico made 4.3s with all the ring gaps lined up don't barf oil out of the throttle body. Hell, a 300,000 mile small block will not do that either.
