rear end
rear end
hey i have a 94 formula and i broke my rear end. my question is can i fit a 97 camaro z28 rear end? both don't have traction control system. what if the 97 does have TCS? what's are the modifications? Thanks.
Chris.
Chris.
The only difference is where the reluctor rings are located. pre 96's use a 3 channle setup and post 96 use 3 and 4 channel set ups. Easy way to tell is if the reluctors are located out behind the axle hubs on the 97 rear. if so then you would have to swap internals I think to add the reluctor inside the rear housing to make your abs system work .
i think it should work, just make sure you know what your gears were and what that one has in case you mix it up(like a manual with a auto rear or vise verse). Sorry but I'm not sure about how the tcs would work or what to do.
