T56 Doesnt like 2nd gear
Car starts perfectly fine.
Goes into 1st fine
go to shift into 2nd and grinds and will not go in.
have to skip to 3rd gear.
Does the same thing on the downshift. grinds 2nd and wont go in.
If im at a dead stop it WILL go into 2nd WITH NO grinding and hold no problem and i can take off in 2nd gear no problems and shift to 3rd with no issues.
So, whats the problem here?
Goes into 1st fine
sounds like a bad synchronizer. pull the trans and find a shop to rebuild it, expect more damage to be found once its pulled apart. its cheaper to replace worn parts now than broken parts later
parts are cheap, but you gotta drop the tranny and the labor is where the $$ is. i have a buddy in bel air MD that builds mine, kind of a drive for you, but hes honest, and that makes the difference for me. i drop them myself drop it off and let him tell me what all is worn/ needs to be attended to. remember there are years of abuse on those gears, and its cheaper in the long run to replace things once than to have the tranny dropped a bunch of times. upgrade your clutch while its out. i think i have a centerforce dual friction around here somewhere if your interested
Stuart, bel air is only like 45 min from me. I need to be able to drive this car down to florida in 2 weeks. About 2500 miles round trip. Do you think, if i avoid 2nd gear, it will be ok?
Any idea what your guy might charge if its just that synchro? I would have to drive the car to him, to have it done. I do not have a way to pull the tranny at home.
If you have to pull the trans for bad synchro, then you should also buy a rebuild kit and have it rebuild right the first time....or you may be doing it again sooner than you think. Or have fun with a permanent 2nd gear "skip shift" As mentioned, it's the labor that is expensive, not the parts. You can get a basic rebuild kit for less than $250 on ebay:
http://www.ebay.com/itm/Borg-Warner-...088#vi-content
2nd gear blocker ring is damaged and or the syncro ring is damaged as well. 1st/2nd syncro ring runs around $170 shipped IIRC. Blocker rings must be bought as a set IIRC. If interested, I have a full set of blocker rings with hardly any wear to the linings and the dog teeth are perfect that I can let go cheap.
You'll be fine on the Florida trip. Hell GM made the cars skip 2nd and 3rd with that gay *** skip shift so I figure you can skip 2nd and be fine. Plus I'm assuming you'll be on the interstate mostly so 5-6 will be where your at.
The drive will be mostly interstate 5th 6th gear.
Does the fact that i can start out in 2nd gear with no problems, change anything diagnosing wise? It grinds 2nd only when the car is in motion.
1 Post
Had the same exact thing happen to me over the summer. Was exactly what wrd1972 said. Chewed up 2nd blacker and 1/2 syncro. Dont make the mistake of forcing it in a lot like I did. Ended up having to get a new 2nd gear set. When I did mine I got the stage 2 rebuild kit from thegearbox.org. Have 2k miles and a track rental on the trans and it holds up great...
