1994 z28 auto i have no1st gear option y??
Old 01-23-2012, 01:22 AM
sav z28's Avatar
Default 1994 z28 auto i have no1st gear option y??
can somebody tell me y i have no 1st gear option
Old 01-23-2012, 01:35 AM
sav z28's Avatar
does anybody no why
Old 01-23-2012, 04:25 AM
lt1slowz28's Avatar
2.73 rear end gear cars don't have it on the selector but it is there... if you get a shifter plate from a v6 car, or any other with the pattern it will be selectable again.
Old 01-23-2012, 04:57 AM
96lt1m6's Avatar
Takes more than a shifter plate.....you have to remove a pin that is in the shifter.
You have a non performance axle ratio option car aka 2.73s find a 6 speed car for the 3.42rear then get your pcm tuned you will love it.
Old 01-23-2012, 05:33 AM
96lt1m6's Avatar
Old 01-23-2012, 07:25 AM
5.slo's Avatar
My car has no 1st gear labeled on the shifter but im able to shift into first, my shifter will go one click under what is labled as second.....which I assume is first. My trans has been rebuilt with all the goodies, shift kit and stall, maybe they took the pin out when they did the rebuild? I have the reciepts for the trans build but it dont mention it anywhere.
Old 01-23-2012, 07:50 AM
ZFreie's Avatar
They must have removed the plastic stop Its not really a pin but a small square piece of plastic that physically prevents the shifter from going into first. I used a putty knife as a chisel when I removed mine and neatly removed it.
Was a sound level thing back in the day, the test was at like 40 mph or something, and with 2.xxs you can get to 45 in first which was over the Db limit, with the 3xxs you can only go 38 (i think, or slower with better gears) which was below the speed need for the test, and a shift into second made it pass. Was a max Db limit while in the lowest gear select-able test at 40(something)mph.
Old 01-23-2012, 08:08 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Welcome to LS1tech!
Some car rental chains would order cars that couldn't be shifted down to first gear. Also, some chain transmission shops such as Aamco would disable shifting down to first gear manually on jobs that they warranty.
Old 01-23-2012, 09:37 AM
2cat95ta's Avatar
I would go with 3.73s not 3.42s unless it's a DD. My 3.23s just are not enough
Old 01-23-2012, 09:59 AM
whytryz28's Avatar
Just cut the plastic stop on the shifter. Did it to mine
Old 01-24-2012, 05:23 PM
jester1614's Avatar
yep its about a 2 minute job
Old 01-25-2012, 03:34 AM
96lt1m6's Avatar
I stated 3.42 rear due to the fact they sell for cheap and way easier to find...... 3.73s would require being set up etc. Costing 550-600 to have in the car. I would rather have 300.00 in my pocket than to be a tenth or two quicker.....
As stated someone may have removed the mechanism that blocks manual 1st gear these cars are OLD now and many have been modded by now.
Old 01-25-2012, 07:18 AM
Paul Bell's Avatar
I was very happy going from 2.73 to 3.42 on my DD.
Old 08-24-2012, 10:56 AM
jwjdw90fbody's Avatar
Where is this plastic peice located?
Old 08-24-2012, 11:00 AM
RamAir95TA's Avatar
Inside the console near the shifter.
Old 05-25-2017, 09:54 AM
Comptonrob's Avatar
anyone have pics of this I've searched
Old 05-27-2017, 02:42 PM
96lt1m6's Avatar
No pics but the job is simple.
Remove the shift plate
Move the shifter from park to low gear and watch where the stop is restricted then just pop that plastic piece off at this point you will be able to shift it down 1 more spot that will enable manual 1st gear.
Old 06-05-2020, 09:14 PM
c.owens's Avatar
I have a 96 with 373s and did this but it only hold first half the time...sometimes it still shifts by itself...any ideas?
Old 06-05-2020, 09:35 PM
pdxmotorhead's Avatar
Transmission RPM limiter in the programming? I thought I read that some rigs have a rpm/speed limit trip to prevent over spinning the insides...
Old 06-05-2020, 10:52 PM
c.owens's Avatar
im not sure...I would think if it was programing it would do it all the time...but some times it will hold 1st long as I want it, and others it will shift at normal driving rpm...haven't read anywhere that doesn't say just cut the stop off the shifter...but also haven't seen ppl saying it was a 96-97, maybe theyre different bc of obd2?
Quick Reply: 1994 z28 auto i have no1st gear option y??
