Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
1993-97 Gen II Small Block V8
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 01-23-2012, 07:34 PM   #1
Garage is empty, add now
Trader Rating: 0
Default 94 Stock LT1: Nitrous & Cam Questions
I have a 94 z28. It is completely stock. My only mods are exhaust and intake.
I am looking to install a cam and valve springs and also nitrous.
I am new to nitrous and lt1 builds, and would greatly appreciate some positive feedback and knowledge!
Best Cam(for use with 100 shot):
Best valve springs:
Best Nitrous Setup(wet or Dry):
Any other supporting mods i would need to make for the above to work at its safest-best potential:
I appreciate your time and help. thanks
murderedoutz is offline   Reply With Quote
Old 01-23-2012, 07:44 PM   #2
coolmanvette75's Avatar
Trader Rating: 1
Nitrous Outlet 93-97 specific LT1 plate kit. Its what I have and plan on spraying 150 in my bolt on 94z
__________________
1994 Medium Patriot Red Z28 6spd
Quick Performance 9", Nitrous Outlet Plate Kit, Mallory 685, Built T56, Pacesetter LT's, 3" True Duals w/ Dynomax Bullets, Tune, 160 T-stat, CSR EWP, Moroso CAI, Walbro 255, MGW shifter, MWC crossmember t/a, Founders SFCs, CE Drag Shocks, Eibach Drag Launch Springs, Granitelli LCAs and Panhard Bar
Best ET: 12.0
Best MPH: 119.1
COMING SOON: Huron Speed Big Single Build
coolmanvette75 is offline   Reply With Quote
Old 01-24-2012, 10:30 AM   #3
Trader Rating: 1
You don't need to consider nitrous use when picking a cam till you are looking at say 250+hp worth which you wont be on an otherwise stock motor even with a cam swap.
Do stall/gears first. When you say "exhaust" does that include headers?
You really should list a lot more info about your car and goals if you want meaningful help.
__________________
96 Caprice with advanced Induction 200cc heads and cam package. 11.567 and 116mph
http://http://i120.photobucket.com/a...eMGR/11567.jpg
http://s120.photobucket.com/albums/o...620at11584.flv
96capricemgr is offline   Reply With Quote
Old 01-24-2012, 12:35 PM   #4
1995 Chevrolet Camaro
My Garage
blakez28's Avatar
Trader Rating: 5
I'm also curious on what's a good "nitrous" cam.
__________________
1998 C5 coupe H/C/I 6.0 m6
Quote:
Originally Posted by GreenBlood55 View Post
Heads are only worth as much as the **** eating grin on your face when going fast.
blakez28 is offline   Reply With Quote
Old 01-24-2012, 01:03 PM   #5
Trader Rating: 1
Quote:
Quote:
By the time you are spraying that big you should have professional help with the engine in the form of a machine shop and a head porter that would be better to ask.
In very broad terms though and again this is for much larger shots of nitrous than being discussed here a "nitrous cam" will have a wider LSA and more intake/exhaust duration split.
On a small shot though those compromises hurt NA power more than they help nitrous power so it is best to leave those optimizations for larger nitrous hits.
__________________
Old 01-24-2012, 01:24 PM   #6
robsquikz28's Avatar
Trader Rating: 229
I have a kit if ur interested?
robsquikz28 is offline   Reply With Quote
Old 01-24-2012, 01:34 PM   #7
Trader Rating: 10
Make sure you upgrade to a walbro 255lph & Nitrous Outlets tech is 2nd to none Their plate or NX maf ends are my choices for LT1 cars
warriorcustoms is offline   Reply With Quote
Old 01-24-2012, 02:04 PM   #8
bowtienut's Avatar
Trader Rating: 0
Per the discussion so far in this thread, the stock cam is an excellent nitrous cam.
__________________
Pat Gish
1996 Impala SS
Stock shortblock, AI cam/heads
10.98 @ 122 on motor, 10.35 @ 128 on the 100-shot
2012 ImpalaSS Nationals SuperPro Champion
bowtienut is offline   Reply With Quote
Old 01-24-2012, 02:38 PM   #9
Trader Rating: 0
im new to this sight and im not sure how to post a new thread but i am thinking about buying a lt1 trans am.. the car has 156k on it but is really clean. i want the car to break 12s by this summer any suggestions on what to do to it? thanks pm me the info it will be greatly appriciated
97transamformula is offline   Reply With Quote
Old 01-24-2012, 02:38 PM   #10
1996 Chevrolet Camaro
96lt1m6's Avatar
Trader Rating: 30
In your situation I would have Longtubes or atleast MAC mids free flowing exhaust. New valve springs, NSA1.7 rockers on 7/16 studs w/ flat plates and hardened pushrods,255lph fuel pump,Cold air or an Ls1 lid set up,3600stall,3.42 gears, tune,MSD digital6 and a NX 150 shot......ET streets and go have fun!
96lt1m6 is offline   Reply With Quote
Old 01-24-2012, 03:32 PM   #11
Trader Rating: 0
im not looking to spend much. theres a guy on ims who has a lt1 camaro with exaust and 150 shot and broke 12s with slicks. how long do these motors usually last like that?
Old 01-24-2012, 04:04 PM   #12
96lt1m6's Avatar
Trader Rating: 30
When I had only exhaust no cats, cold AIR,150 shot, dragradials and No tune...... I went from 13.9na to 12.2 on a 150 shot back in '03 and now my best with Longtubes,tune,1.6rr and 4.10s added to the above I run 12.9na and 11.3 on the same 150 shot. My Lt1 has seen tooooooo many bottles of N2O Nitrous and Lt1s work very nice together.
Old 01-24-2012, 04:11 PM   #13
Trader Rating: 0
Thanks for the info. As per requested to list more about my car and goals:
Stock 94z. 120k miles. Manual trans.
Only mods are K&N Cold Air Intake, 3'' exhaust, flowmaster, No Cat, Stock Header
My goal is to have a fun street car, as fast as possible on a budget of around 3000.
Once the car needs a rebuild i would then like an ls swap of some kind.
I was thinking about a cam, valvesprings, 100 shot, long tubes, and a tune.
Please give me feedback! thanks!
Old 01-24-2012, 04:29 PM   #14
Trader Rating: 1
If bothering to put a kit on I would go ahead and be prepared to run 150hp through it, go ahead and start smaller work your way up learning and tuning, but with decent tune a 150shot is easy and reliable on an LT1, a lot of guys have gone 175 and some go higher, one wingnut with a stock shortblock Impala successfully did 2 stages for a total of 280hp. Most endup scattering the motor when they aim high like that and I have seen a few cases where with stock(unported) heads guys didn't gain anymore past 175 because the system just got so choked.
I would put gears in it, will make it nicer to drive all the time.
__________________
Old 01-24-2012, 04:41 PM   #15
Trader Rating: 0
what size of cam can you do with the stock lifters springs retainers ect?
Old 01-24-2012, 07:21 PM   #16
Trader Rating: 1
If you want something that works well with stock springs then you need to find a cam SMALLER than stock. The stock cam actually benefits from more spring.
The lifters are good enough for pretty much any reasonable hydraulic cam.
The retainers have to match whatever spring you choose.
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
150, 1995, 96, bolt, build, cam, engine, good, impala, kit, lt1, nitrous, shot, size, stock, whats, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
