car reving when pulled out of gear at stops
lately i have noticed that when i pull the car out of gear while coming to a stop sign/light the rpms will bounce around from about 1200 up to 2000 for a while until it finally goes back to idle. it continues to do this even after i am completely stopped and i can put the car in gear and slightly let off the clutch and it will immediatly stop doing this but i was wondering what could be causing this because its starting to get very annoying. what is causing this?
Think my old M6 did that too it had a pcmforless tune as well. Not sure why but just throwing it out there so you arnt thinking "mine is the only one that does it" type of problem.
My car did the same thing after PCM for less tune for cam, headers ect. I put in a new tps and IAC and didn't change anything. I e mailed them back and ask them what's up. I was told they don't get aggressive on the IAC programming or return to idle programing because a M6 car has a tendency to die with a larger cam. He told me to make a small adjustment to the throttle stop screw. I did that several times and so far it seem to be ok. It doesn't drop to idle immediately, kind of takes its time a second or so. But when it idles it does not jump around. He told me if I wasn't happy with it to send him back the PCM and he would adjust the tables.
I have a pcmforless tune also converted to a m6 and adjusted the screw on it also seems to help
Mine was tuned locally by a friend of the guy who owned car before me and I'm waiting o get mail order tune till after I put headers and tb on. Throttle does not jump around at idle once car is at operating temp and i dont have the problem from the op all the time maybe once or twice a day in town
