Pulled the intake and found some milky oil
Old 01-29-2012, 06:40 PM
slow96ss's Avatar
Default Pulled the intake and found some milky oil
I'm about to pull valve covers but i was wondering if anyone had suggestions on why the milkshake is there
Old 01-29-2012, 06:49 PM
94fixerTA's Avatar
Water or fuel in oil.
Old 01-29-2012, 06:52 PM
slow96ss's Avatar
Gunk was above #7
Old 01-29-2012, 06:58 PM
94fixerTA's Avatar
I've also seen some higher milage motors with it under the valve covers that had no problems.
Old 01-29-2012, 07:01 PM
slow96ss's Avatar
Ok cool mines got 180k
Old 01-29-2012, 07:28 PM
guppymech's Avatar
Mung inside valve cover, is normal on car that doesn't routinely reach operating temperature. White stuff in lifter valley is not normal. Are you loosing coolant? Drain oil and see what comes out.
Old 01-29-2012, 07:33 PM
ZFreie's Avatar
OP, do you have a 160* t-stat?
Old 01-29-2012, 08:21 PM
LTX
LTX's Avatar
blown head gasket maybe.
Old 01-29-2012, 08:33 PM
94fixerTA's Avatar
Let's start with why you pulled the intake off?
Old 01-29-2012, 08:35 PM
slow96ss's Avatar
Changed oil about 2 weeks ago an oil was fine but I have stock t-stat and intake was pulled to fix leak in the rear
Old 01-29-2012, 08:45 PM
94fixerTA's Avatar
That could be the reason for the milky stuff.
Old 01-29-2012, 08:46 PM
Jerry Clayton's Avatar
#1 intake port doesn't look like others and #1 exhaust pipe doesn't look same as 3,5,7 ---
Old 01-30-2012, 12:10 AM
slow96ss's Avatar
Ya the port does look different but the exhaust pipe is alright just looks funny in the pic. No big deal though im ordering different ones next week anyway and the valve cover gunk is actualy above #1 not 7
Old 01-30-2012, 01:21 AM
MasterTomos's Avatar
Is the motor in a cold place? (sorry if that sounds stupid) but in the winter time this often happens to oil in a vehicle.
Old 01-30-2012, 02:48 AM
slow96ss's Avatar
It's outside all the time and takes on the Illinois winter. Been pretty cold here lately
Old 01-30-2012, 11:32 AM
When I worked at the tire and lube express almost every car that came in in the winter looked like that under the oil cap. I bet it is just the cold weather, especially if it is sitting outside.
Old 01-30-2012, 11:41 AM
SexyTransAm's Avatar
check the compression, and coolant system pressure test.
Old 01-30-2012, 01:43 PM
esoteric18's Avatar
Id agree with this, seems youd get alot of conclusions out of it
Old 01-30-2012, 02:02 PM
FormulaJoe's Avatar
I noticed that too. Seems to me like OP is 1 cylinder short.
Old 01-30-2012, 05:39 PM
lt-1guy96's Avatar
Looks like normal condensation drive it 200 miles and see if you loose any coolant but its not a headgasket if you dont have any driveability problems..or pressure test the cooling system with the intake off and see if its seeping in the valley that could be possible
Quick Reply: Pulled the intake and found some milky oil
