LT1 stumbles after it gets warm
I need some help troubleshooting engine issue, maybe this happened to someone before.
when its cold and for the first 5 to ten min. of driving, it drives fine, once it the temp needle starts moving, the engine starts hesitating or stumbling but with a little more gas it moves just fine then hesitates again like not all cyl are firing. Also, I'm smelling a lot more exhaust than before. It almost feels like the cat is plugged but I figured if that was the case it would run the same warm or cold. I think it would be the same case for a dirty fuel filter.
--Just read another thread about a similar issue, got to check the O2 sensors.
any other ideas?
thanks.
any other ideas?
thanks.
Village Troll
Two easy checks:
Jack car up with jackstands and check to make sure w/p is not leaking onto opti. Mine would be have the same way. What would happen is it would run fine when cold, but once pressure started building in cooling system it would leak from the w/p onto the opti causing the engine to stumble yet would be fine at full throttle. You should see coolant stains out of the weephole of the w/p and surrounding areas if it is indeed leaking.
If that checks out, unplug the O2 sensors and drive around again and see if it still behaves strangely.
Two easy checks:
