Oil holes above filter
Old 02-05-2012, 10:52 AM
SPOOOOLIN's Avatar
Default Oil holes above filter
Ok, If you have been following me throughout the build IT RUNS!!! my last post was about the rockers rubbing, all is good!
Next problem, I have oil pissing out of a whole on the side of the block right above the oil filter.
Not my engine, but it shows the holes Im talking about.
Do both of these have to be plugged or just the bottom one, or am I missing something that goes in the top hole. I have a plug in the bottom one but oil is still comming out. PLEASE HELP!!!
Old 02-05-2012, 10:56 AM
RamAir95TA's Avatar
The bottom hole needs to be plugged (it's 1/4" NPT IIRC, so if you're using a bolt then that's not going to work) - the top one is just an unused blind threaded hole, probably used for handling at the factory or for some other accessory.
Old 02-05-2012, 11:13 AM
SPOOOOLIN's Avatar
HMMM, I Have a plug in there, mabee i need to put some teflon tape on it. DAMNIT
Old 02-05-2012, 11:15 AM
RamAir95TA's Avatar
Tape would help, especially considering it's under up to 60+ psig.
Old 02-05-2012, 11:19 AM
SPOOOOLIN's Avatar
thanks for the help guys!!!
Old 02-05-2012, 11:46 AM
shbox's Avatar
http://shbox.com/1/aux_oil_port.jpg
Quick Reply: Oil holes above filter
