Lt1 cam choice for DD
Old 02-07-2012, 06:47 PM
1baddgarage's Avatar
Default Lt1 cam choice for DD
Hey everyone, I'm new here as this is my first LT1. I just picked up my 94 camaro Saturday, decided to get rid of my gutless 96 mustang gt. Never a fan of the 4.6. Anyways it already has Longtube headers, Off road Y, 3 inch exhaust, slp cold air. So I was looking at camming the car this summer. Its my daily, so nothing too radical, looking at the cc305 or cc503. I want enough power to pull on my brothers c5 (around mid 12s, 325-350rwhp), but still have stockish idle and decent mpg. I was leaning towards the cc305 for the idle quality but heard alot of people are disapointed with it. Which would be your reccomendation for a daily driver and why.
Old 02-07-2012, 06:56 PM
pancho toco loco's Avatar
lt4 hot cam or 503cc...... Both are very proven with the right set-up and tune... Good driving quailty and not radical at idle. Anywhere from 320-350 rwho depending on dyno tune and a4 or 6spd
Old 02-07-2012, 07:02 PM
gregrob's Avatar
Both have lazy lobes. Do something like the XFI 466
Old 02-07-2012, 07:04 PM
96lt1m6's Avatar
LPE 211/219
CC305
CC503
Custom grind from LE Or AI
Old 02-07-2012, 07:17 PM
96capricemgr's Avatar
Of the recommended I would scratch the 305 and the HOT for sure so old and lazy there is really no reason.
The 503 is a proven performer.
The XFI lobes like gregrob suggested are designed to use moder spring technology BUT you need to exercise a little caution as Comp's rpm ranges are a good 400+rpms less than you will actually turn which can make their spring recommendations insufficient. It looks like Comp recommends the 918beehive with that cam and I think in this case that will work, but they also recommend that spring for some larger cams and it can have some trouble. Some people have tried dual springs with the XFI lobes and had trouble.
What are you thinking about gears/stall(if applicable)?
Old 02-07-2012, 07:19 PM
bowtienut's Avatar
The CC503 does not have lazy lobes. The 305 does, and is basically a loser for an NA engine.
That LPE 211/219 is one of the best off-the-shelf sleeper cams. None of the others mentioned will have a stockish idle.
If you can find a Crane 227, that would fit your requirements nicely.
But, honestly, just bypass mediocrity, spend the extra $100 and go straight to AI or LE for one of their custom cams that is optimized for your stock heads, your performance/DD goals, and your valvetrain durability expectations. And be SURE to run the supporting valvetrain components that either of them recommends!
whytryz28's Avatar
Went with the hotcam in my lt1 since I was able to get it for only $75 shipped with only 2k miles.
Old 02-07-2012, 07:20 PM
gregrob's Avatar
I've used that cam and other XFI cams with patriot dual and no issues at all...
They aren't even as aggressive as some of the modern LS street lobes with a 1.7 rocker.
I wouldn't use 918s though.
Old 02-07-2012, 07:25 PM
gregrob's Avatar
Yes it does... 224 @ .050 and 276 @ .006 subtract the two and you have 52... and it has **** for lift ...
Lazy
The only way I would consider running one is on 1.7 rockers
Old 02-07-2012, 07:34 PM
Stock rear gears, I should have mentioned its a m6. Are the XFI lobes going to be harder on the valvetrain? Durability is a priority, I already have another car for when I want some serious hp, so I don't need to get everylast hp out of this one.
Old 02-07-2012, 07:42 PM
bowtienut's Avatar
Lazy
You're definition of lazy is different from mine. I'm going by what I read from his post - sleeper, DD, durability, etc.
If you're talking a street/strip brawler, then yes I agree with you.
Old 02-07-2012, 07:46 PM
I was looking at the cc503 and cc305 mainly due to popularity and being able to buy them used. After the car is done being my dd I do want to get heads and a cam from LE and go with a turbo setup. I will be sure to get the valvetrain setup right though. Just asking for trouble otherwise lol
Old 02-07-2012, 07:59 PM
nascarnate326's Avatar
join up mifbody since I see you are in michigan.
I would look into a 226 234 cam from AI. Joeliusz28 on youtube has it and its pretty sweet.
Old 02-07-2012, 08:10 PM
I'm already a member since this is my second camaro, haven't been on there in awhile though. That cam does sound pretty sweet, a little more than I want for my dd though. You ever make it up to grand rapids or do you mainly stay around battle creek area?
Old 02-07-2012, 08:17 PM
so it looks like the cc503 is the all around winner besides a custom cam, thanks for the help everyone. Now I just gotta convince the wife its going to up the mpg or something lol
Old 02-07-2012, 08:58 PM
mcalus's Avatar
I go to Allendale all the time to visit my gf. I'm in the process of building my car with a cam pretty close to the one Nate posted.
IMO, I have heard the hotcam is the way to go. You can pick up a used kit for cheap!
Old 02-07-2012, 09:28 PM
Far as durability with something like the XFI lobes you just need to buy good springs instead of the cheapest springs that fit. There were some growing pains early on when those lobes were released with Comp switching to an offshore manufacturer but there are a lot more spring options these days.
If you want to do it once and do it well you could spend the extra on say a nitrided spring.
I actually think I know someone looking to sell an AI 226/234 cam if interested I can send an email. It wont pass for stock though.
Really I think Pat made a good point, if you want stock sound the LPE 211/219 is a really good choice.
Old 02-07-2012, 10:34 PM
Wicked94Z's Avatar
Pac 1219, newer 26918 from Comp (associated) or manley 221428 (associated) will work fine with the XFI stuff. I'd suggest a custom with an XFI/XE lobe combination and a healthy I/E split.
Old 02-08-2012, 12:15 AM
I think that AI 226/234 is a bit much for my DD, but thanks though. The LPE 211/219 is interesting, how well does it perform? I can't seem to find much information on it. The tamest cam to reach my goal is what im looking for really. I plan on taking it all apart in 2 years and getting serious with it then, until then 325-350 rwhp sounds great to me.
Old 02-08-2012, 12:38 AM
gregrob's Avatar
My custom XFI 216 226 was dead reliable and made 340 rwhp with gobs of torque...
Just throwing that out there.
Quick Reply: Lt1 cam choice for DD
