Cost to rebuild shortblock
I have an 1994 lt1 engine mains and piston rings are shot, i'm going to drop the motor out soon tear it down to nothing but a shortblock what is the average cost .30 355 rebuild?
well its not knocking i just hear the mains on startup and the engine smokes really bad oil blowing out the PCV hose
How many miles on the engine, that would determine what parts I would replace because everything has a fatigue cycle. at the least I would add forged pistons and better rods (Scat Pro Comp I beams with ARP 2000 cap screws) along with ARP head and main bolts. That would give you a solid foundation to build on should you choose to up the power later.
Uh depending on the rods and crank still being good... rough prices.
$180-$220 to bore/hone
$600 for Mahle power pack forged with moly rings
$250 to balance rotating assembly
$300 bearings/gaskets
Might as well do a cam/springs/lifters/pushrods/rockers while it's apart (tack on another $1,000).
Thing is if the engine is actually that worn you need to figure out what damaged it or you will ruin a new engine.
If the mains spun then the block might not be worth trying to salvage.
Also keep in mind what these guys are quoting is no head work and if they want to do a head "rebuild" for $300 I would not let them screwup the castings, heads are where power is and worthwhile work cost money.
car has 140k miles engine still holds 50 psi oil pressure at idle needle doesn't fluctuate tested with mechanical gauge and goes up in the rpms mains cant be that bad maybe an understatment, not rebuilding the topend rebuilt that last summer not even 1k miles on that.
