Got in running oil pressure?
I got my motor running today an I have 22 lbs at idle when warm does that seem alright I am running 10w 30 when I rev it up is goes to up really good over 60 then
5w-30 is recommended because of CAFE not because it is best. That is NOT to say 10w-30 is better or worse. In some brands 10w-30 is thinner at operating temps than 5w-30 or 0w-30.
30weight is a RANGE not a specific measurement.
That said 22psi is PLENTY for a smallblock to idle, they really don't need much pressure.
Also with my smaller cam swap before pulling the motor and changing cam an what not to a bigger one they both seem to stay at 2 or 2100 rpm an not want to idle down when driving it what could that be bad tune? An I haven't had it tuned yet for this cam. I am using the same tune as I was for my cc502 cam untill I get it dyno an no I'm not going to be driving it alot or if anything just had to road test it today
absolutly i idle mine at 20psi and at 8200 rpm i have a mere 50psi........and on the last inspeciton my bearings looked like brand new after two years of 8000+rpm abuse.....less pressure = less power wasted spinning the pump
