g2
"*** GOOD" I have one of these "gay" intakes The biggest difference in it and the K&N is the filter assembly itself...the K&N has a cone filter and block off plate to keep engine heat out...the G2 just utilizes the stock intake box and recommends you cut the plastic off one side to expose the whole air filter...or you do what I did and make your own cone filter setup. I used some Specter 4" tubing and one of their big cone filters. I would say K&N is better unless you add a cone filter.
